Call Transfer Failed WHY
Discussion in '3CX Phone System - General' started by sohaibwcws, Sep 19, 2008.
  1. sohaibwcws
    Sep 19, 2008
    10
    hello all,
    i just installed 3cx and everything is working fine, but when ever I enter the extension it rings but after couple seconds it says call transfer failed ? and then it played my greetings again, do you know what I am doing wrong.
  2. sohaibwcws
    Sep 19, 2008
    10
    I figured out a way I wasnt sure on the outbound rules so I set those up and now its working fine.
