call transfer failed.
Discussion in '3CX Phone System - General' started by jmatson, Feb 26, 2010.
  1. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    my setup is as follows.
    pap2 and that connects to a 3102 to my wife's analog phone.
    2 days ago when someone hits her extension It says call transfer failed. I got it working yesterday and today dead again. It's registered inside with 3cx. here are the logs.
    15:15:26.788 [CM503016]: Call(24): Attempt to reach <sip:101@127.0.0.1:5060> failed. Reason: Not Found
    15:15:26.787 [todo] Call(24): Can not call sip:101@10.1.10.12:5060: there's no free SLA appearance
    15:15:26.787 Failed to acquire SLA slot for DN 101; TODO: Do proper message
    15:15:26.786 [todo] Call(24): Can not call sip:101@10.1.10.12:5061: there's no free SLA appearance
    15:15:26.786 Failed to acquire SLA slot for DN 101; TODO: Do proper message
    15:15:26.785 [todo] Call(24): Can not call sip:101@10.1.10.33:5062: there's no free SLA appearance
    15:15:26.785 Failed to acquire SLA slot for DN 101; TODO: Do proper message
    15:15:26.737 [CM503004]: Call(24): Route 1: Ext:Ext.101@[Dev:sip:101@10.1.10.33:5062,Dev:sip:101@10.1.10.12:5061,Dev:sip:101@10.1.10.12:5060]
    15:15:26.736 [CM503010]: Making route(s) to <sip:101@127.0.0.1:5060>
    15:15:26.735 [CM505003]: Provider:[888Voip] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:jessandbetty@74.93.147.250:5060]
    15:15:21.657 [MS211000] C:24.1: 4.55.5.130:8658 is delivering DTMF using RTP payload (RFC2833). In-Band DTMF tone detection is disabled for this call segment.
  2. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    anyone have any suggestions. been a wk of not being able to get calls
  3. Demoh
    Jan 7, 2010
    Same problem as well. Calling it in right now.
  4. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Do you run free version or licensed one?
