Call Transfer Failed
Discussion in '3CX Phone System - General' started by cpinero, Feb 2, 2009.
  1. cpinero
    Apr 26, 2008
    12
    I am trying to setup virtual extension that will forward a call to an external number. Every time I dial the number I get a "Call Transfer Failed" message.
    From suggestions in other posts I have added an outbound rule by adding a prefix to the external number but I still cannot get it to work. In the extension settings I have:
    Forward All -> All Hours -> All Calls -> Forward to External Number 9xxxxxxxxx
    The nine (9) is the prefix for the outbound rule.
    If calls are forwarded using the cfwd feature of the phone, the forwarding of calls works perfectly, but I need virtual extension for different external numbers.
    Any ideas of what could be wrong??
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    if you call the Virtual extension internally does it work...and connect you to the external number?
    Are you sure that you do not have an Outbound rule based on extension making the call? If you have outbound rules based on extension making the call remove them temporarily OR create a catch all Outbound rule at the bottom of the list.
    Can you reproduce the issue and attach the Verbose logs of such a call?
  3. cpinero
    Apr 26, 2008
    12
    If the extension is dialed internally the transfer works with no problems.
    All outbound rules are based on prefix numbers, none have extensions associated with them.
    This is the log when the call fails:
    16:26:30.609 [CM503008]: Call(144): Call is terminated
    16:26:27.562 [MS210005] C:144.2:Answer provided. Connection(proxy mode):127.0.0.1:7104(7105)
    16:26:27.562 [MS210001] C:144.1:Answer received. RTP connection: 192.168.1.160:5012(5013)
    16:26:27.562 Remote SDP is set for legC:144.1
    16:26:27.453 [MS210004] C:144.1:Offer provided. Connection(proxy mode): 192.168.1.180:7102(7103)
    16:26:27.453 [MS210000] C:144.2:Offer received. RTP connection: 127.0.0.1:40708(40709)
    16:26:27.453 Remote SDP is set for legC:144.2
    16:26:27.125 [CM503015]: Call(144): Attempt to reach <sip:402@127.0.0.1:5060> failed. Reason: Reason Unknown
    16:26:27.125 [CM503003]: Call(144): Call to sip:1305xxxxxxx@194.221.62.198:5060 has failed; Cause: 400 Bad request; from IP:194.221.62.198:5060
    16:26:26.781 [CM503004]: Call(144): Calling: VoIPline:1305xxxxxxx@(Ln.10008@Poivy)@[Dev:sip:xxxxxxxxxxxxxxxx@194.221.62.198:5060]
    16:26:26.625 [CM503010]: Making route(s) to <sip:402@127.0.0.1:5060>
    16:26:26.625 Refer: from="DR800:"<sip:800@127.0.0.1:5060>;tag=15420b21; to="WIRELESS CALLER"<sip:305xxxxxxx@127.0.0.1:5060>;tag=d0363c51; RefTo=<sip:402@127.0.0.1:5060>
    16:26:26.296 [MS210003] C:144.2:Answer provided. Connection(transcoding mode):127.0.0.1:7104(7105)
    16:26:26.296 [MS210001] C:144.1:Answer received. RTP connection: 192.168.1.160:5012(5013)
    16:26:26.296 Remote SDP is set for legC:144.1
    16:26:26.187 [MS210002] C:144.1:Offer provided. Connection(transcoding mode): 192.168.1.180:7102(7103)
    16:26:26.187 [MS210000] C:144.2:Offer received. RTP connection: 127.0.0.1:40708(40709)
    16:26:26.187 Remote SDP is set for legC:144.2
    16:26:17.109 Session 50801 of leg C:144.1 is confirmed
    16:26:17.031 [CM503007]: Call(144): Device joined: sip:800@127.0.0.1:40600;rinstance=b8779f494d3c9131
    16:26:17.015 [CM503007]: Call(144): Device joined: sip:10002@192.168.1.160:5064
    16:26:17.015 [CM505001]: Ext.800: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX IVR;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] Transport: [sip:127.0.0.1:5060]
    16:26:17.015 [MS210005] C:144.1:Answer provided. Connection(proxy mode):192.168.1.180:7102(7103)
    16:26:17.015 [MS210001] C:144.2:Answer received. RTP connection: 127.0.0.1:40708(40709)
    16:26:17.000 Remote SDP is set for legC:144.2
    16:26:17.000 [CM503002]: Call(144): Alerting sip:800@127.0.0.1:40600;rinstance=b8779f494d3c9131
    16:26:16.500 [MS210004] C:144.2:Offer provided. Connection(proxy mode): 127.0.0.1:7104(7105)
    16:26:16.500 [CM503004]: Call(144): Calling: Ext:Ext.800@[Dev:sip:800@127.0.0.1:40600;rinstance=b8779f494d3c9131]
    16:26:16.500 [CM503010]: Making route(s) to <sip:800@192.168.1.180:5060>
    16:26:16.500 [MS210000] C:144.1:Offer received. RTP connection: 192.168.1.160:5012(5013)
    16:26:16.500 Remote SDP is set for legC:144.1
    16:26:16.500 [CM505002]: Gateway:[GXW4104 Miami] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 1.0, Ch:2) 1.0.1.10] Transport: [sip:192.168.1.180:5060]
    16:26:16.484 [CM503001]: Call(144): Incoming call from 305xxxxxxx@(Ln.10002@GXW4104 Miami) to <sip:800@192.168.1.180:5060>
    16:26:16.484 [CM503012]: Inbound office hours rule for 10002 forwards to DN:800
    16:26:16.484 Looking for inbound target: called=10000+; caller=305xxxxxxx
    16:26:16.453 [CM500002]: Info on incoming INVITE:
    INVITE sip:10000+@192.168.1.180 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.160:5064;branch=z9hG4bK71b3cbf5cdc6d231
    Max-Forwards: 70
    Contact: <sip:10002@192.168.1.160:5064>
    To: <sip:10000+@192.168.1.180>
    From: "WIRELESS CALLER"<sip:305xxxxxxx@192.168.1.180>;tag=f624849411a03d97
    Call-ID: e5f241d77bb0b064@192.168.1.160
    CSeq: 18920 INVITE
    Allow: INVITE, ACK, CANCEL, BYE, NOTIFY, REFER, OPTIONS, INFO, SUBSCRIBE, UPDATE, PRACK
    Proxy-Authorization: Digest username="10002",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:10000+@192.168.1.180",nonce="12878169976:47c4ce69bfc8cdd373b2f42a846e3f7f",response="d3b05ac2a769f9ddbc2e77692a63fd53"
    Supported: replaces, timer, path
    User-Agent: Grandstream GXW4104 (HW 1.0, Ch:2) 1.0.1.10
    Content-Length: 0
    This is the log if dialed internally:
    16:24:45.656 [CM503008]: Call(143): Call is terminated
    16:24:35.125 [CM505003]: Provider:[Poivy] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.1.180:5060]
    16:24:35.125 [MS210005] C:143.1:Answer provided. Connection(proxy mode):192.168.1.180:7100(7101)
    16:24:35.125 [MS210001] C:143.2:Answer received. RTP connection: 195.219.64.173:25504(25505)
    16:24:35.125 Remote SDP is set for legC:143.2
    16:24:35.125 [CM503002]: Call(143): Alerting sip:tropicaltextiles@194.221.62.198:5060
    16:24:34.578 [MS210004] C:143.2:Offer provided. Connection(proxy mode): 70.148.132.248:9042(9043)
    16:24:34.500 [CM503004]: Call(143): Calling: VoIPline:1305xxxxxx@(Ln.10008@Poivy)@[Dev:sip:xxxxxxxxxxxxxxxx@194.221.62.198:5060]
    16:24:34.343 [CM503010]: Making route(s) to <sip:402@192.168.1.180>
    16:24:34.343 [MS210000] C:143.1:Offer received. RTP connection: 192.168.1.101:16476(16477)
    16:24:34.343 Remote SDP is set for legC:143.1
    16:24:34.343 [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA922-6.1.3(a)] Transport: [sip:192.168.1.180:5060]
    16:24:34.328 [CM503001]: Call(143): Incoming call from Ext.100 to <sip:402@192.168.1.180>
    16:24:34.328 [CM500002]: Info on incoming INVITE:
    INVITE sip:402@192.168.1.180 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.101:5060;branch=z9hG4bK-9d55fe09
    Max-Forwards: 70
    Contact: "Carlos Pinero"<sip:100@192.168.1.101:5060>
    To: <sip:402@192.168.1.180>
    From: "Carlos Pinero"<sip:100@192.168.1.180>;tag=686688f8fe0f019o0
    Call-ID: 4b86b5a4-7ca8cb5d@192.168.1.101
    CSeq: 102 INVITE
    Expires: 240
    Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
    Proxy-Authorization: Digest username="100",realm="3CXPhoneSystem",nonce="12878169874:19ec284e2751976f0e2c291e9c978a59",uri="sip:402@192.168.1.180",algorithm=MD5,response="2700ba51d3d87db87bde9966d844b24f"
    Supported: replaces
    User-Agent: Linksys/SPA922-6.1.3(a)
    Content-Length: 0
    Thanks,
    Carlos Pinero
  4. gonzo__007
    Nov 11, 2008
    44
    I had the same issue.
    my outbound rule was from ext201 to my voip provider
    I added a secound outbound rule for number starting with "1" and I select to don't stip any digit.
    then in the unregistred ext, I forward call to: 1 xxx xxx xxxx (without spaces)
  5. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    It looks as though the outbound call is going through a proxy from internal when it succeeds, but there is no proxy involved when coming from external through the Vegastream.
  6. cpinero
    Apr 26, 2008
    12
    If the problem is using the proxy how can I force to use the proxy on external calls through the Grandstream??
