Call Transfer - flash time
Discussion in '3CX Phone System - General' started by zadean, May 22, 2008.
  1. zadean
    May 30, 2007
    14
    Installed a Siemens Gigaset C450 as an extension. Documentation says: To transfer a call to another phone operating behind a PABX you have to set the flash time from the operating system. If it is set press the R key and dial the internal number (given from the PABX).
    How do I set the flash time on 3CX? Pressing R key doesnt work.
    Defalt Settings in phone are:
    DTMF Over VoIP Connections
    Send Settings : Audio
    HOOK FLASH:
    Application type : dtmf-relay
    Application signal: 16
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    304
    Flash is for analog phone systems. If only call transfer were that easy in SIP! :)
    VOIP phone systems use a SIP command for it. So not sure what exactly that phone is but that setting relates to connection to an analog PBX.
  3. zadean
    May 30, 2007
    14
    I have analogue lines as well as voip lines. Using a Grandstream 4104 gateway.
  4. Philco
    Philco Member
    Nov 10, 2007
    364
    Hi Zadean. If your hand sets are VOIP/SIP types there should be a transfer button, or there may be a * command that will allow a transfer.
    On analogue phones into an ATA such as a Grandstream then the recall button (FLASH) or a star command is used, depending on whether a blind or attended transfer is required.
    Phil
  5. zadean
    May 30, 2007
    14
    Hi Phil. I am using a SIP handset. (Siemens C450IP), it has a R button, but it doesnt work. In the handbook it says "To transfer a call to another phone operating behind a PABX you have to set the flash time from the operating system. If it is set press the R key and dial the internal number (given from the PABX). "
    I cannot see where to set this from 3CX.
  6. Philco
    Philco Member
    Nov 10, 2007
    364
    Hi Zadean, I guess its not designed for transfering voip calls, which is surprising. The grandstream ATAs when on a VOIP call (in or out) recognise the recall button is pressed as a line break (equivalent to pressing on hook for several hundered ms) this gives a second VOIP dialing tone to transfer a call.
    This works too on Dect phones connected to their ATAs where the phone has a recall button.
    Phil
  7. AndreasMetal
    Nov 16, 2007
    62
    Hey!
    Check this: http://www.voip-info.org/wiki/view/Siemens+Gigaset+C450IP ,the section "Enabling call transfer feature"
  8. AndreasMetal
    Nov 16, 2007
    62
    Sorry, the preview message was for asterisk :(
    In AnalogPhones can Flash Time be setted from phones menu.
    Siemens C450IP has also webmanagment. It may has your requested feature!
  9. lino
    Jun 11, 2008
    Has anybody solved the problem of "R" Key on C450 Gigaset with 3CX?
    I cannot transfer any call, could you please help me.
    On 3cx PBX there is another key sequence to hold and tranfer calls?
  10. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    3CX PBX doesn't use any key sequences to transfer. It process SIP REFER request to initiate transfer.
  11. lino
    Jun 11, 2008
    Thanks Archie.
    So I cannot use Siemens C450 with 3Cx? .... The "r" key does not work on VOIP
    I cannot hold and transfer the call in any other mode?
    Lino
