Call Transfer from receptionist console
Discussion in '3CX Phone System - General' started by ChrisPriest, Mar 2, 2010.
  1. ChrisPriest
    Feb 17, 2010
    20
    Hi All,
    We are currently deploying our system company wide and are doing a few tests to ensure everything is as it should be.
    We are using Aastra 57i handsets and the reception has one of these with 2 expansion modules attached, the BLF's are configured as Transfer keys as well, when she transfers a call through to an idle phone, this works as expected, however if the extension is busy, when she tries to transfer it reports transfer failed and the call is returned to her.
    The extension is configured to go to voicemail when busy, so I would have expected the call to be transferred into the extensions voicemail box.
    Am I going bonkers and missing something? :)
    Best Regards
    Chris
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Hi Chris,
    Does it work as expected if you transfer the call using phone buttons (not BLF extension button)?
  3. ChrisPriest
    Feb 17, 2010
    20
    Hi Sy,
    Yes, if she presses Xfer <ext> Xfer, the call is transferred to voice mail if the extension is busy.
    Best Regards
    Chris
  4. comresource
    comresource Member
    May 22, 2009
    303
    Can you post the section from the phone config related to the Speedial/Xfer button.
  5. ChrisPriest
    Feb 17, 2010
    20
    This is just the config for the blf button for my extension on her expansion module:
    expmod1 key3 type: blfxfer
    expmod1 key3 label: "C Priest"
    expmod1 key3 value: 5426
    Is this what you meant?
    Best Regards
    Chris
  6. comresource
    comresource Member
    May 22, 2009
    303
    Yes, thanks. I wanted to test using the exact config. It works on my expansion module as it should. If line is busy...and extension is set to Use PBX Status, when I hit the BLF/Xfer button it went straight to voicemail. One thing to keep in mind.. You say you are using 2X Aastra side cars which adds up to 120 configurable buttons. Aastra has a limit of 50 for BLF configured buttons, I am not sure what happens if you configure more that that.
  7. ChrisPriest
    Feb 17, 2010
    20
    Hi comresource,
    Yeah, I was aware of that, I think currently we only have about 45 BLF's displayed, two modules were used so the BLF's could all be seen on one page.
    I have my extension set to use PBX status, oddly (or perhaps not) if I set it to use phone status, then the transfer works and the call appears on Line 2, giving me the option to accept or ignore it, if I ignore it, it get's dumped off to voicemail.
    I'll continue to investigate and try and find out what's happening from the logs.
    Cheers for the input tho :)
    Chris
  8. ChrisPriest
    Feb 17, 2010
    20
    Ok, go figure.
    We just tried it again this morning and it works as expected......*beats head against wall* lol
    Oh well, at least it does what I expect it to do.
    Thanks again for the input guys.
    Cheers
    Chris
  9. Elis
    Feb 24, 2010
    5
    please I need help, How do I transfer from the SPA-3102 when I'm talking on the phone, with * 9 does not work
    regards
  10. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Use flash hook.
