- Joined
- Dec 15, 2008
- Messages
- 4
- Reaction score
- 0
We are running 3CX Phone system V12, and using the Gigaset N510 IP PRO.
When an outside is connected to person A evertything goes well.
The problem occurs when person A is internal atendant transfering the call to person B. They can hear eachother, but when the person A is actually transfering the call to person B the call is going directly to voicemail.
The log file:
11-Mar-2015 10:14:58.809 Leg L:736.3[Extn] is terminated: Cause: BYE from xxx.xxx.xxx.xxx:xxxx
11-Mar-2015 10:14:58.578 [CM503007]: Call(C:736): VMail:999 has joined, contact <sip:[email protected]:40600>
11-Mar-2015 10:14:58.570 L:736.5[VMail] has joined to L:736.2[Line:10000>>085XXXXXXX]
11-Mar-2015 10:14:58.372 [CM503025]: Call(C:736): Calling T:VMail:999@[Dev:sip:[email protected]:40600;rinstance=3dd958014a3c158d] for L:736.2[Line:10000>>085XXXXXXX]
11-Mar-2015 10:14:58.364 Leg L:736.4[Extn] is terminated: Cause: 486 Busy Here/INVITE from xxx.xxx.xxx.xxx:xxxx
11-Mar-2015 10:14:58.361 [CM503005]: Call(C:736): Forwarding: T:VMail:999@[Dev:sip:[email protected]:40600;rinstance=3dd958014a3c158d]
11-Mar-2015 10:14:58.361 L:736.2[Line:10000>>085XXXXXXX] forwards call from Extn:103 to VMail:999 based on rule Fwd[Available/Busy]
11-Mar-2015 10:14:58.361 L:736.2[Line:10000>>085XXXXXXX] failed to reach Extn:103, reason Busy
(the X's are numbers of course)
Is there anyone who probably knows a solution to this?
Thanks in advance,
Kind regards,
Remco Verbiest
Servicenet ITF
Terneuzen, The Netherlands.
The log file:
Thanks in advance,
Kind regards,
Remco Verbiest
Servicenet ITF
