Call Transfer in Latest Version
Discussion in 'Windows' started by fra88er, Dec 14, 2009.
  1. fra88er
    Dec 14, 2009
    I have just installed the latest version of 3CXPhone v4.0.9878.0. In the previous version v4.0.8913.0 I was able to do both an attended and unattended transfers using the tranfer button. In this latest version it no longer gives you the option, it merely asks for the number to transfer and blindly transfers the call.
    Is it a config issue or has the functionalty been removed?
    Regards and thank you in advance for any help.
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,528
    71
    Attended transfer is a transfer to an established call - that means from line to line, as any hardphone (like Grandstream) or softtphone (like Xlite) does. 3CXPhone has exactly the same behavior.
    However, the next release will provide a setting allowing to use (or not) the old transfer dialog.
  3. fra88er
    Dec 14, 2009
    Can you provide any indication when the next version will be available? The attended transfer was a very nice feature that I would like to see return.
