Call Transfer need to improve
Discussion in '3CX Phone System - General' started by aslam, May 22, 2016.
  1. aslam
    May 22, 2016
    32
    Right now the calls getting transferred blindly with out confirm whether the end user is physically avail on desk. This is good at certain scenarios but in some case the client calls get dropped if the end user not there on the desk and they may have to contact back couple of times.
    So if there is an option in transfer er to check the physical presence by talking to them and connect the line would good I think. Like in traditional PBX system
  2. uptime1
    uptime1 New Member
    Jan 13, 2012
    112
    30
    Search in the manual for Attended Transfer.
  3. aslam
    May 22, 2016
    32
    It works fine :)....Thank you so much.
