call transfer problem
Discussion in '3CX Phone System - General' started by avacchet, Oct 2, 2008.
  1. avacchet
    Oct 2, 2008
    Hi im testing 3cx pbx. i have a problem when i do a transfer form an internal call to an other internal number.
    this is the log.
    Call::Terminate [CM503008]: Call(60): Call is terminated
    11:05:40.737 Call::Terminate [CM503008]: Call(60): Call is terminated
    11:05:35.846 MediaServerReporting::RTPReceiver [MS105000] C:61.1: No RTP packets were received:remoteAddr=0.0.0.0:5006,extAddr=0.0.0.0:0,localAddr=192.168.2.4:7364
    11:05:35.846 MediaServerReporting::RTPReceiver [MS105000] C:61.2: No RTP packets were received:remoteAddr=0.0.0.0:10002,extAddr=0.0.0.0:0,localAddr=192.168.2.4:7366
    11:05:35.846 Call::RouteFailed [CM503015]: Call(60): Attempt to reach [sip:102@192.168.2.4?Replaces=32bbfe5d7fc9f894%40192.168.2.124%3Bfrom-tag%3D8a2f8ab7cb89403e%3Bto-tag%3D0c0e5227] failed. Reason: Reason Unknown
    11:05:35.846 CallLeg::eek:nFailure [CM503003]: Call(60): Call to sip:102@192.168.2.4 has failed; Cause: 200 OK; from IP:192.168.2.39:5060
    11:05:35.768 Call::Terminate [CM503008]: Call(61): Call is terminated
    11:05:35.580 MediaServerReporting::RTPSender [MS004000] C:61.2: (ACTIVE): Can't send RTP stream to 0.0.0.0:10002 destination unreachable
    11:05:35.580 MediaServerReporting::RTPSender [MS004000] C:61.1: (ACTIVE): Can't send RTP stream to 0.0.0.0:5006 destination unreachable
    11:05:31.908 CallCtrl::eek:nLegConnected [CM503007]: Call(61): Device joined: sip:102@192.168.2.39
    11:05:31.908 CallCtrl::eek:nLegConnected [CM503007]: Call(61): Device joined: sip:104@192.168.2.124:5060
    11:05:31.893 Extension::printEndpointInfo [CM505001]: Ext.102: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [V1.00.01] Transport: [sip:192.168.2.4:5060]
    11:05:31.893 CallCtrl::eek:nAnsweredCall [CM503002]: Call(61): Alerting sip:102@192.168.2.39
    11:05:30.346 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(61): Calling: Ext:Ext.102@[Dev:sip:102@192.168.2.39]
    11:05:30.346 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:102@192.168.2.4]
    11:05:30.330 Extension::printEndpointInfo [CM505001]: Ext.104: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream BT200 1.1.1.14] Transport: [sip:192.168.2.4:5060]
    11:05:30.330 CallCtrl::eek:nIncomingCall [CM503001]: Call(61): Incoming call from Ext.104 to [sip:102@192.168.2.4]
    11:05:21.564 MediaServerReporting::RTPSender [MS004000] C:60.2: (ACTIVE): Can't send RTP stream to 0.0.0.0:5004 destination unreachable
    11:05:21.564 MediaServerReporting::RTPSender [MS004000] C:60.1: (ACTIVE): Can't send RTP stream to 0.0.0.0:10006 destination unreachable
    11:05:11.939 CallCtrl::eek:nLegConnected [CM503007]: Call(60): Device joined: sip:104@192.168.2.124:5060
    11:05:11.939 CallCtrl::eek:nLegConnected [CM503007]: Call(60): Device joined: sip:100@192.168.2.37
    11:05:11.330 Extension::printEndpointInfo [CM505001]: Ext.104: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream BT200 1.1.1.14] Transport: [sip:192.168.2.4:5060]
    11:05:11.314 CallCtrl::eek:nAnsweredCall [CM503002]: Call(60): Alerting sip:104@192.168.2.124:5060
    11:05:11.220 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(60): Calling: Ext:Ext.104@[Dev:sip:104@192.168.2.124:5060]
    11:05:11.220 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to "104"[sip:104@192.168.2.4]
    11:05:11.220 Extension::printEndpointInfo [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [V1.00.01] Transport: [sip:192.168.2.4:5060]
    11:05:11.220 CallCtrl::eek:nIncomingCall [CM503001]: Call(60): Incoming call from Ext.100 to "104"[sip:104@192.168.2.4]
    what can i do to resolve this?
    thanks in advance
  2. avacchet
    Oct 2, 2008
    phone was BT200 and voismart 101 and also softphone, but i've resolved . option auto re-invite causes the problems!
    thanks
