Call Transfer through Digital receptionist
Discussion in 'Windows' started by Manikandan, Sep 27, 2008.
  1. Manikandan
    Sep 27, 2008
    I am transferring the call from Digital receptionist to an external extension . The external phone rings . but there is no sound for the caller On Hold .. When the external extension is call directly the caller hers the calling ring tone ! .
    If there is no sound on the call transfer the caller thinks :roll: the phone is dead.
  2. Manikandan
    Sep 27, 2008
    Yes its External Extension . when i call from local to external extension it rings ! but when i transfer through Digital Receptionist the hold sound does do play . But in the other end it rigs and able to attend the call . i don't think it is a firewall issue . because local to external is working properly ! ....
  3. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    he Matt, but i have also this problem with an mobile number.
