Call transfer with Siemens S685IP
Discussion in '3CX Phone System - General' started by ansu2723, Jun 22, 2009.
  1. ansu2723
    Nov 23, 2008
    29
    I dont get it to work
    Possible settings
    Call Transfer
    Use the R key to initiate call transfer with the SIP Refer method.: Yes No
    Transfer Call by On-Hook: Yes No
    Preferred Refer To: Original URL Target's contact info
    Automatic Refer To: Yes No
    What should I choose?
  2. Hanzz
    Jun 11, 2009
    11
    I have the same problem with 470IP....I'am solving it with Siemens Tech-Support.....
    If I get some response, I'll write to you....
  3. Hanzz
    Jun 11, 2009
    11
    Hello, I have answer from Gigaser support, that transfers work ONLY from menu / transfer.
