08:47:53.513 [CM503008]: Call(192): Call is terminated
08:47:10.092 [MS105000] C:193.2: No RTP packets were received:remoteAddr=10.10.10.190:11780,extAddr=0.0.0.0:0,localAddr=10.10.10.8:7246
08:47:09.842 [MS210005] C:192.6:Answer provided. Connection(proxy mode):10.10.10.8:7248(7249)
08:47:09.842 [MS210001] C:192.1:Answer received. RTP connection[unsecure]: 196.38.164.132:12502(12503)
08:47:09.842 Remote SDP is set for legC:192.1
08:47:09.748 [CM503007]: Call(192): Device joined: sip:[email protected]:5062
08:47:09.748 [MS210004] C:192.1:Offer provided. Connection(proxy mode): 196.209.238.151:9010(9011)
08:47:09.733 [MS210000] C:192.6:Offer received. RTP connection: 10.10.10.190:11782(11783)
08:47:09.733 Remote SDP is set for legC:192.6
08:47:09.733 [CM505001]: Ext.12: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Yealink SIP-T22P 7.60.0.140] PBX contact: [sip:[email protected]:5060]
08:47:09.733 [CM503002]: Call(192): Alerting sip:[email protected]:5062
08:47:09.717 [CM503008]: Call(193): Call is terminated
08:47:09.592 [CM503025]: Call(192): Calling @[Dev:sip:[email protected]:5062]
08:47:09.529 Relpaces: [email protected];to-tag=8200f601;from-tag=2303d87d
08:47:09.529 Refer: from=<sip:[email protected]>;tag=7748a13e; to="Incoming call:MAS:0119023748"<sip:[email protected]:5060>;tag=47681b00; RefTo=<sip:[email protected]?Replaces=725619f672c2a01e479e4c6e69abee7d%4010.10.10.191%3Bto-tag%3D8200f601%3Bfrom-tag%3D2303d87d>
08:47:09.233 [MS210003] C:193.1:Answer provided. Connection(transcoding mode[unsecure]):10.10.10.8:7244(7245)
08:47:09.233 [MS210001] C:193.2:Answer received. RTP connection[unsecure]: 10.10.10.190:11780(11781)
08:47:09.233 Remote SDP is set for legC:193.2
08:47:09.014 [MS210002] C:193.2:Offer provided. Connection(transcoding mode): 10.10.10.8:7246(7247)
08:47:09.014 [MS210000] C:193.1:Offer received. RTP connection: 0.0.0.0:60002(60003)
08:47:09.014 Remote SDP is set for legC:193.1
08:47:07.358 Session 71474 of leg C:193.1 is confirmed
08:47:07.092 [CM503007]: Call(193): Device joined: sip:[email protected]:5062
08:47:07.076 [CM503007]: Call(193): Device joined: sip:[email protected]:5060
08:47:07.076 [MS210007] C:193.1:Answer provided. Connection(by pass mode): 10.10.10.190:11780(11781)
08:47:07.076 [MS210001] C:193.2:Answer received. RTP connection[unsecure]: 10.10.10.190:11780(11781)
08:47:07.076 Remote SDP is set for legC:193.2
08:47:05.764 [CM505001]: Ext.12: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Yealink SIP-T22P 7.60.0.140] PBX contact: [sip:[email protected]:5060]
08:47:05.764 [CM503002]: Call(193): Alerting sip:[email protected]:5062
08:47:05.420 [CM503025]: Call(193): Calling Ext:Ext.12@[Dev:sip:[email protected]:5062]
08:47:05.420 [MS210006] C:193.2:Offer provided. Connection(by pass mode): 10.10.10.191:60002(60003)
08:47:05.373 [CM503004]: Call(193): Route 1: Ext:Ext.12@[Dev:sip:[email protected]:5062]
08:47:05.373 [CM503010]: Making route(s) to <sip:[email protected]>
08:47:05.373 [MS210000] C:193.1:Offer received. RTP connection: 10.10.10.191:60002(60003)
08:47:05.373 Remote SDP is set for legC:193.1
08:47:05.373 [CM505001]: Ext.10: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [CM5K-PHONE (803060)] PBX contact: [sip:[email protected]:5060]
08:47:05.358 [CM503001]: Call(193): Incoming call from Ext.10 to <sip:[email protected]>
08:47:05.358 [CM500002]: Info on incoming INVITE:
INVITE sip:[email protected] SIP/2.0
Via: SIP/2.0/UDP 10.10.10.191:5060;rport=5060;branch=z9hG4bK6809528bb6
Max-Forwards: 70
Contact: <sip:[email protected]:5060>
To: <sip:[email protected]>
Call-ID: [email protected]
CSeq: 2 INVITE
Allow: INVITE, CANCEL, ACK, BYE, NOTIFY, REFER, OPTIONS, INFO, MESSAGE, UPDATE
Proxy-Authorization: Digest username="10",realm="3CXPhoneSystem",nonce="414d535c04d6906900:04812316cf07f79e4a6e93b77d0396d1",response="daf23927f755310c3ba7f8d9d70f139c",uri="sip:[email protected]",algorithm=MD5
Supported: replaces
User-Agent: CM5K-PHONE (803060)
Allow-Events: talk, hold, conference
Content-Length: 0
08:47:03.233 [MS210005] C:192.4:Answer provided. Connection(proxy mode):10.10.10.8:7240(7241)
08:47:03.233 [MS210001] C:192.1:Answer received. RTP connection[unsecure]: 196.38.164.132:12502(12503)
08:47:03.233 Remote SDP is set for legC:192.1
08:47:03.092 [MS210002] C:192.1:Offer provided. Connection(transcoding mode): 196.209.238.151:9010(9011)
08:47:03.092 [MS210000] C:192.4:Offer received. RTP connection: 0.0.0.0:60000(60001)
08:47:03.092 Remote SDP is set for legC:192.4
08:46:58.608 [CM503003]: Call(192): Call to sip:[email protected] has failed; Cause: 487 Request Terminated; from IP:10.10.10.200:5062
08:46:58.483 Session 71445 of leg C:192.1 is confirmed
08:46:58.483 [CM503003]: Call(192): Call to sip:[email protected] has failed; Cause: 487 Request Terminated; from IP:10.10.10.183:5062
08:46:58.467 [CM503003]: Call(192): Call to sip:[email protected] has failed; Cause: 487 Request Terminated; from IP:10.10.10.176:5062
08:46:58.373 [CM503007]: Call(192): Device joined: sip:[email protected]:5060
08:46:58.358 [CM503007]: Call(192): Device joined: sip:[email protected]:5060
08:46:58.358 [MS210005] C:192.1:Answer provided. Connection(proxy mode):196.209.238.151:9010(9011)
08:46:58.358 [MS210001] C:192.4:Answer received. RTP connection[unsecure]: 10.10.10.191:60000(60001)
08:46:58.358 Remote SDP is set for legC:192.4
08:46:49.749 [CM505001]: Ext.11: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Yealink SIP-T22P 7.60.0.140] PBX contact: [sip:[email protected]:5060]
08:46:49.749 [CM503002]: Call(192): Alerting sip:[email protected]:5062
08:46:49.577 [CM505001]: Ext.16: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Yealink SIP-T20P 9.60.0.140] PBX contact: [sip:[email protected]:5060]
08:46:49.577 [CM503002]: Call(192): Alerting sip:[email protected]:5062
08:46:49.545 [CM505001]: Ext.10: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [CM5K-PHONE (803060)] PBX contact: [sip:[email protected]:5060]
08:46:49.545 [CM503002]: Call(192): Alerting sip:[email protected]:5060
08:46:49.483 [CM505001]: Ext.13: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Yealink SIP-T20P 9.60.0.140] PBX contact: [sip:[email protected]:5060]
08:46:49.483 [CM503002]: Call(192): Alerting sip:[email protected]:5062
08:46:49.280 [CM503025]: Call(192): Calling RingAll80:16Ext.1611Ext.1110Ext.1013Ext.13@[Dev:sip:[email protected]:5062]
08:46:49.264 [MS210004] C:192.5:Offer provided. Connection(proxy mode): 10.10.10.8:7242(7243)
08:46:49.264 [CM503025]: Call(192): Calling RingAll80:16Ext.1611Ext.1110Ext.1013Ext.13@[Dev:sip:[email protected]:5060]
08:46:49.264 [MS210004] C:192.4:Offer provided. Connection(proxy mode): 10.10.10.8:7240(7241)
08:46:49.264 [CM503025]: Call(192): Calling RingAll80:16Ext.1611Ext.1110Ext.1013Ext.13@[Dev:sip:[email protected]:5062]
08:46:49.249 [MS210004] C:192.3:Offer provided. Connection(proxy mode): 10.10.10.8:7238(7239)
08:46:49.249 [CM503025]: Call(192): Calling RingAll80:16Ext.1611Ext.1110Ext.1013Ext.13@[Dev:sip:[email protected]:5062]
08:46:49.249 [MS210004] C:192.2:Offer provided. Connection(proxy mode): 10.10.10.8:7236(7237)
08:46:49.202 [CM503004]: Call(192): Route 1: RingAll80:16Ext.1611Ext.1110Ext.1013Ext.13@[Dev:sip:[email protected]:5062,Dev:sip:[email protected]:5062,Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5062]
08:46:49.202 [CM503010]: Making route(s) to <sip:[email protected]:5060>
08:46:49.202 [MS210000] C:192.1:Offer received. RTP connection: 196.38.164.132:12502(12503)
08:46:49.202 Remote SDP is set for legC:192.1
08:46:49.202 [CM505003]: Provider:[Switch] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [SwitchTelecom] PBX contact: [sip:[email protected]:5060]
08:46:49.186 [CM503001]: Call(192): Incoming call from 0119023748@(Ln.10000@Switch) to <sip:[email protected]:5060>
08:46:49.124 [CM503012]: Inbound office hours rule (MAS) for 10000 forwards to DN:80
08:46:49.124 Looking for inbound target: called=0875500600; caller=0119023748
08:46:49.124 [CM500002]: Info on incoming INVITE:
Via: SIP/2.0/UDP 196.38.164.132:5060;branch=z9hG4bK4cca9b82;rport=5060
Max-Forwards: 70
From: "0119023748"<sip:[email protected]>;tag=as6ceb20ed
Call-ID: [email protected]:5060
CSeq: 102 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Date: Fri, 18 Nov 2011 06:46:49 GMT
Supported: replaces, timer
User-Agent: SwitchTelecom
Content-Length: 0
08:46:16.890 [CM503008]: Call(190): Call is terminated
08:45:37.250 [MS105000] C:191.2: No RTP packets were received:remoteAddr=10.10.10.190:11798,extAddr=0.0.0.0:0,localAddr=10.10.10.8:7232
08:45:36.047 [MS210005] C:190.6:Answer provided. Connection(proxy mode):10.10.10.8:7234(7235)
08:45:36.047 [MS210001] C:190.1:Answer received. RTP connection[unsecure]: 196.38.164.132:18552(18553)
08:45:36.047 Remote SDP is set for legC:190.1
08:45:35.937 [CM503007]: Call(190): Device joined: sip:[email protected]:5062
08:45:35.937 [MS210004] C:190.1:Offer provided. Connection(proxy mode): 196.209.238.151:9008(9009)
08:45:35.937 [MS210000] C:190.6:Offer received. RTP connection: 10.10.10.190:11800(11801)
08:45:35.937 Remote SDP is set for legC:190.6
08:45:35.937 [CM505001]: Ext.12: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Yealink SIP-T22P 7.60.0.140] PBX contact: [sip:[email protected]:5060]
08:45:35.937 [CM503002]: Call(190): Alerting sip:[email protected]:5062
08:45:35.922 [CM503008]: Call(191): Call is terminated
08:45:35.797 [CM503025]: Call(190): Calling @[Dev:sip:[email protected]:5062]
08:45:35.734 Relpaces: [email protected];to-tag=211b7f3b;from-tag=31e9dbff
08:45:35.734 Refer: from=<sip:[email protected]>;tag=0257348e; to="Incoming call:MAS:0828765001"<sip:[email protected]:5060>;tag=bb38453e; RefTo=<sip:[email protected]?Replaces=0eee969a51e1601e236d7b9168cb7ec2%4010.10.10.191%3Bto-tag%3D211b7f3b%3Bfrom-tag%3D31e9dbff>
08:45:35.453 [MS210003] C:191.1:Answer provided. Connection(transcoding mode[unsecure]):10.10.10.8:7230(7231)
08:45:35.453 [MS210001] C:191.2:Answer received. RTP connection[unsecure]: 10.10.10.190:11798(11799)
08:45:35.438 Remote SDP is set for legC:191.2
08:45:35.297 [MS210002] C:191.2:Offer provided. Connection(transcoding mode): 10.10.10.8:7232(7233)
08:45:35.125 [MS210000] C:191.1:Offer received. RTP connection: 0.0.0.0:60002(60003)
08:45:35.125 Remote SDP is set for legC:191.1
08:45:33.781 Session 71425 of leg C:191.1 is confirmed
08:45:33.531 [CM503007]: Call(191): Device joined: sip:[email protected]:5062
08:45:33.531 [CM503007]: Call(191): Device joined: sip:[email protected]:5060
08:45:33.516 [MS210007] C:191.1:Answer provided. Connection(by pass mode): 10.10.10.190:11798(11799)
08:45:33.516 [MS210001] C:191.2:Answer received. RTP connection[unsecure]: 10.10.10.190:11798(11799)
08:45:33.516 Remote SDP is set for legC:191.2
08:45:29.484 [CM505001]: Ext.12: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Yealink SIP-T22P 7.60.0.140] PBX contact: [sip:[email protected]:5060]
08:45:29.484 [CM503002]: Call(191): Alerting sip:[email protected]:5062
08:45:29.109 [CM503025]: Call(191): Calling Ext:Ext.12@[Dev:sip:[email protected]:5062]
08:45:29.109 [MS210006] C:191.2:Offer provided. Connection(by pass mode): 10.10.10.191:60002(60003)
08:45:29.063 [CM503004]: Call(191): Route 1: Ext:Ext.12@[Dev:sip:[email protected]:5062]
08:45:29.063 [CM503010]: Making route(s) to <sip:[email protected]>
08:45:29.063 [MS210000] C:191.1:Offer received. RTP connection: 10.10.10.191:60002(60003)
08:45:29.063 Remote SDP is set for legC:191.1
08:45:29.063 [CM505001]: Ext.10: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [CM5K-PHONE (803060)] PBX contact: [sip:[email protected]:5060]
08:45:29.047 [CM503001]: Call(191): Incoming call from Ext.10 to <sip:[email protected]>
08:45:29.047 [CM500002]: Info on incoming INVITE:
Via: SIP/2.0/UDP 10.10.10.191:5060;rport=5060;branch=z9hG4bK8d42758c71
Max-Forwards: 70
CSeq: 2 INVITE
Proxy-Authorization: Digest username="10",realm="3CXPhoneSystem",nonce="414d535c04d6900812:d31cc77091d377ae302760b649d8d9b9",response="6a1bcf6855ada1291504f01174c65f9d",uri="sip:[email protected]",algorithm=MD5
Supported: replaces
Content-Length: 0
08:45:26.172 [MS210005] C:190.4:Answer provided. Connection(proxy mode):10.10.10.8:7226(7227)
08:45:26.172 [MS210001] C:190.1:Answer received. RTP connection[unsecure]: 196.38.164.132:18552(18553)
08:45:26.172 Remote SDP is set for legC:190.1
08:45:26.047 [MS210002] C:190.1:Offer provided. Connection(transcoding mode): 196.209.238.151:9008(9009)
08:45:26.047 [MS210000] C:190.4:Offer received. RTP connection: 0.0.0.0:60000(60001)
08:45:26.031 Remote SDP is set for legC:190.4
08:44:59.391 Session 71406 of leg C:190.1 is confirmed
08:44:59.376 [CM503003]: Call(190): Call to sip:[email protected] has failed; Cause: 487 Request Terminated; from IP:10.10.10.183:5062
08:44:59.376 [CM503003]: Call(190): Call to sip:[email protected] has failed; Cause: 487 Request Terminated; from IP:10.10.10.200:5062
08:44:59.360 [CM503003]: Call(190): Call to sip:[email protected] has failed; Cause: 487 Request Terminated; from IP:10.10.10.176:5062
08:44:59.251 [CM503007]: Call(190): Device joined: sip:[email protected]:5060
08:44:59.251 [MS210005] C:190.1:Answer provided. Connection(proxy mode):196.209.238.151:9008(9009)
08:44:59.251 [MS210001] C:190.4:Answer received. RTP connection[unsecure]: 10.10.10.191:60000(60001)
08:44:59.251 Remote SDP is set for legC:190.4
08:44:48.095 [CM505001]: Ext.11: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Yealink SIP-T22P 7.60.0.140] PBX contact: [sip:[email protected]:5060]
08:44:48.095 [CM503002]: Call(190): Alerting sip:[email protected]:5062
08:44:48.048 [CM505001]: Ext.10: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [CM5K-PHONE (803060)] PBX contact: [sip:[email protected]:5060]
08:44:48.048 [CM503002]: Call(190): Alerting sip:[email protected]:5060
08:44:48.048 [CM505001]: Ext.13: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Yealink SIP-T20P 9.60.0.140] PBX contact: [sip:[email protected]:5060]
08:44:48.048 [CM503002]: Call(190): Alerting sip:[email protected]:5062
08:44:47.985 [CM505001]: Ext.16: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Yealink SIP-T20P 9.60.0.140] PBX contact: [sip:[email protected]:5060]
08:44:47.985 [CM503002]: Call(190): Alerting sip:[email protected]:5062
08:44:47.798 [CM503025]: Call(190): Calling RingAll80:16Ext.1611Ext.1110Ext.1013Ext.13@[Dev:sip:[email protected]:5062]
08:44:47.782 [MS210004] C:190.5:Offer provided. Connection(proxy mode): 10.10.10.8:7228(7229)
08:44:47.782 [CM503025]: Call(190): Calling RingAll80:16Ext.1611Ext.1110Ext.1013Ext.13@[Dev:sip:[email protected]:5060]
08:44:47.782 [MS210004] C:190.4:Offer provided. Connection(proxy mode): 10.10.10.8:7226(7227)
08:44:47.782 [CM503025]: Call(190): Calling RingAll80:16Ext.1611Ext.1110Ext.1013Ext.13@[Dev:sip:[email protected]:5062]
08:44:47.767 [MS210004] C:190.3:Offer provided. Connection(proxy mode): 10.10.10.8:7224(7225)
08:44:47.767 [CM503025]: Call(190): Calling RingAll80:16Ext.1611Ext.1110Ext.1013Ext.13@[Dev:sip:[email protected]:5062]
08:44:47.767 [MS210004] C:190.2:Offer provided. Connection(proxy mode): 10.10.10.8:7222(7223)
08:44:47.720 [CM503004]: Call(190): Route 1: RingAll80:16Ext.1611Ext.1110Ext.1013Ext.13@[Dev:sip:[email protected]:5062,Dev:sip:[email protected]:5062,Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5062]
08:44:47.720 [CM503010]: Making route(s) to <sip:[email protected]:5060>
08:44:47.720 [MS210000] C:190.1:Offer received. RTP connection: 196.38.164.132:18552(18553)
08:44:47.720 Remote SDP is set for legC:190.1
08:44:47.720 [CM505003]: Provider:[Switch] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [SwitchTelecom] PBX contact: [sip:[email protected]:5060]
08:44:47.704 [CM503001]: Call(190): Incoming call from 0828765001@(Ln.10000@Switch) to <sip:[email protected]:5060>
08:44:47.642 [CM503012]: Inbound office hours rule (MAS) for 10000 forwards to DN:80
08:44:47.642 Looking for inbound target: called=0875500600; caller=0828765001
08:44:47.626 [CM500002]: Info on incoming INVITE:
Via: SIP/2.0/UDP 196.38.164.132:5060;branch=z9hG4bK5cb1c5ed;rport=5060
Max-Forwards: 70
From: "0828765001"<sip:[email protected]>;tag=as7c03d77a
CSeq: 102 INVITE
Date: Fri, 18 Nov 2011 06:44:47 GMT
Content-Length: 0
Max-Forwards: 70
Supported: replaces
CSeq: 102 INVITE
CSeq: 102 INVITE
08:43:49.221 [CM503003]: Call(189): Call to sip:[email protected] has failed; Cause: 487 Request Terminated; from IP:10.10.10.191:5060
08:43:49.158 [CM503003]: Call(189): Call to sip:[email protected] has failed; Cause: 487 Request Terminated; from IP:10.10.10.183:5062
08:43:49.033 [CM503007]: Call(189): Device joined: sip:[email protected]:5062
08:43:49.018 [MS210005] C:189.1:Answer provided. Connection(proxy mode):196.209.238.151:9006(9007)
08:43:49.018 Remote SDP is set for legC:189.2
08:43:45.111 [CM503002]: Call(189): Alerting sip:[email protected]:5062
08:43:45.049 [CM503002]: Call(189): Alerting sip:[email protected]:5062
08:43:45.002 [CM503002]: Call(189): Alerting sip:[email protected]:5060
08:43:44.940 [CM503002]: Call(189): Alerting sip:[email protected]:5062
08:43:44.721 [MS210004] C:189.5:Offer provided. Connection(proxy mode): 10.10.10.8:7220(7221)
08:43:44.721 [MS210004] C:189.4:Offer provided. Connection(proxy mode): 10.10.10.8:7218(7219)
08:43:44.705 [MS210004] C:189.3:Offer provided. Connection(proxy mode): 10.10.10.8:7216(7217)
08:43:44.705 [MS210004] C:189.2:Offer provided. Connection(proxy mode): 10.10.10.8:7214(7215)
08:43:44.658 [CM503010]: Making route(s) to <sip:[email protected]:5060>
08:43:44.658 Remote SDP is set for legC:189.1
08:43:44.643 [CM503001]: Call(189): Incoming call from 0828765001@(Ln.10000@Switch) to <sip:[email protected]:5060>
08:43:44.565 Looking for inbound target: called=0875500600; caller=0828765001
Max-Forwards: 70
Content-Length: 0
08:39:59.975 [CM503008]: Call(188): Call is terminated
08:37:46.384 Session 71282 of leg C:188.1 is confirmed
08:37:46.368 [CM503003]: Call(188): Call to sip:[email protected] has failed; Cause: 487 Request Terminated; from IP:10.10.10.183:5062
08:37:46.322 [CM503007]: Call(188): Device joined: sip:[email protected]:5060
