Call Transfer
Discussion in '3CX Phone System - General' started by Anonymous, Sep 6, 2006.
  1. Anonymous
    Anonymous Guest
    I've tried the beta at it is very nice. Interface is clear and the options seems to be very complete.
    I was wondering if call transfer will also be possible to an external telephonenumber like cellphone or something like that. Is that possible in the final version?
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Thank you for your nice feedback!
    The call transfer should work fine even in current beta if the route to external telephone leads through gateway or VoIP provider that supports processing of SIP message 'REFER' (RFC 3265). Otherwise it will not work in current version.
