call trasfer with linksys PAP2???
Discussion in '3CX Phone System - General' started by simones181170, Jan 11, 2008.
  1. simones181170
    Dec 4, 2007
    51
    i've 3 IP phone and 2 Cordless connected with Linksys Pap2
    the call trasfer with the IP Phone works well
    i can't trasfer the call with the cordless ( with the V3 works ) but doesn't work with V5
  2. simones181170
    Dec 4, 2007
    51
    now it works
    i've change the Hook Flash Timer
    Hook Flash Timer Min: 0.06
    Hook Flash Timer Max: 0.2
    and now i can transfer to the other Ext with R
