Solved Call using 3cx client form voicemail to email
Discussion in 'iOS' started by neville, Dec 23, 2016.
  1. neville
    neville New Member
    Apr 23, 2012
    222
    39
    When I get an voicemail to email and check it on my IPhone, the caller id shows up. Is there a way to return the call via the 3CX client by hitting the caller id number? This would be a great feature. Currently on my IPhone, it will only call via GSM.
    I have the latest client on both the IPhone and the 3CX client.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,530
    298
