Call Waiting Display on Yealink T48G
Discussion in '3CX Phone System - General' started by Joshua Stump, Mar 14, 2017.
  1. Joshua Stump
    Mar 9, 2017
    10
    Does anyone know how to change the display of incoming calls through call waiting? Currently when they ring in, it just displays the name of the caller without the number so we're seeing a ton of "Wireless Callers" without numbers.. I can't find any option for this on the phone nor the config file for the phone.
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    813
    46
    Please login and try this setting in the T48G:
    Settings>Call Display>Call Information Display Method>Name+Number
  3. Joshua Stump
    Mar 9, 2017
    10
    That's already the option. Normal calls display that way, but a call waiting call displays with just the name.
