Call Waiting
Discussion in '3CX Phone System - General' started by jwalsh, Sep 30, 2013.
  1. jwalsh
    Sep 30, 2013
    On version 11.
    Have two users that would like incoming calls that come while on a call to go to voicemail automatically. Or possibly that they get set as "away" while on a call. Is this possible, and if not, is it available in version 12. I'm just not finding any call waiting settings anywhere.
  2. rbc94
    Apr 24, 2012
    40
    Turn off the option for the extension to receive more than one call at a time in the management console.
  3. jwalsh
    Sep 30, 2013
    Thanks very much for that.
