Call Waiting
Discussion in '3CX Phone System - General' started by layton, Feb 19, 2014.
  1. layton
    Jan 18, 2011
    46
    OK - I have weird issue.
    Just going live with a new 3CX 2012 SP3 install with Yealink T46G phones (all running firmware 28.71.0.176) where call waiting isn't acting as expected all of the time. If the receptionist is on a call and someone internal calls her extension, she sees a second call coming in & can choose to put the first call on hold & pick up the second call. This of course is the expected (& desired) behavior.
    Where it gets interesting is when an outside call comes in. All outside calls are going to a ring group. If the receptionist is on an active call when another external call comes into the ring group, her phone does not ring the second call at all - only the other extensions in the ring group. This isn't limited to just the receptionist's extension - we are seeing this behavior with all extensions in the ring group(s).
    All extensions have Call Waiting enabled in their forwarding preferences, all extensions are currently showing an Available status, and the ring groups are set to a "Ring All" strategy. I've compared these settings with the settings for our internal 3CX system (also v12 SP3 with the same Yealink T46G phones on the same firmware) - and everything seems to match.
    Here's an example of what I'm seeing in the logs:
    19-Feb-2014 15:15:48.002 L:143.1[Line:10000<<4028809045] forwards call from RingAll:811 to RingAll:812 based on rule
    19-Feb-2014 15:15:48.002 L:143.1[Line:10000<<4028809045] failed to reach RingAll:811, reason Temporarily Unavailable
    19-Feb-2014 15:15:48.002 [CM503026]: Call(C:143): Route 1 to RingAll811[Ext.301,Ext.311] is not active (Busy/Not registered)
    19-Feb-2014 15:15:48.002 L:143.1[Line:10000<<4028809045] target's endpoint Extn:311 is Busy
    19-Feb-2014 15:15:48.002 L:143.1[Line:10000<<4028809045] target's endpoint Extn:301 is Busy
    19-Feb-2014 15:15:48.001 [CM503001]: Call(C:143): Incoming call from Line:10000<<########## to <sip:811@fe80::94f2:c438:a500:6dc5:5060>
    Basically, ring group 811 contains two extensions (301 & 311) that are the primary call handlers. We have a secondary ring group set up (812) that has the primary call handlers (301 & 311) as well as 3 other extensions. So if a call that rings the first ring group isn't answered in 15 seconds, it rolls over to the second ring group. The above logs show that even though both extensions 301 & 311 have their call waiting enabled - 3CX is detecting them as busy and rolling over to the 812 ring group instead of 811. And even then the extensions are not being rang even though they are part of the 812 ring group.
    So what stupidly simple thing am I missing? :)
    Thanks!
    Chad
  2. layton
    Jan 18, 2011
    46
    Don't be confused by my saying 3CX 2012 - should be v12. Not sure where 2012 came from :)
  3. CentrexJ
    CentrexJ Member
    May 5, 2009
    432
    67
    #3 CentrexJ, Feb 19, 2014
  4. layton
    Jan 18, 2011
    46
    Perfect - I had completely forgotten about that, and my searches weren't pulling anything up.
    Thanks!
    Chad
