Call Whisper
Discussion in '3CX Phone System - General' started by AlexHitchins, Mar 4, 2013.
  1. AlexHitchins
    Jun 19, 2012
    5
    Is it possible to set up a call whisper in 3CX? For example, I have a 100 CLI DDI range where each line needs to be answered with a custom introduction ("thank you for calling company x", "Hello, you are through to company y enquiry line" etc.). I can’t see where this could be configured.
    The preferred process is that the phone rings, is auto answered and a recorded message informs the operator the name of the line. The call is then put straight through and the operator greets the caller with the right welcome script.
    Perhaps if this isn't possible there is another way the same result could be achieved?
    11,116
    329
    The recordings could be accomplished by routing a call through an automated attendant, that then passes the call on without the callers intervention. The caller information could be added to call display depending on how your incoming calls are set up. Voice announce, of the caller information would not be possible without some sort of external device.
  3. AlexHitchins
    Jun 19, 2012
    5
    Thanks leejor,
    The main thing that I need to ensure is that an operator answering the phone knows how to answer the call. That can be via a voice announce (ideal) or text on screen.
  4. leejor
    11,116
    329
    This is one of the post regarding appending the Queue or Ring group name to caller ID.
    http://www.3cx.com/forums/appending-ring-group-name-after-caller-id-8200.html
    One problem that has come up however, is the limited number of characters available on some phone displays. This results in truncated names/numbers. If you are doing some testing of this, it might be an idea to keep the names short, until you are sure that a longer name won't result in missing information.
  5. AlexHitchins
    Jun 19, 2012
    5
    I'll check that link out and post back my findings - thank you so much for finding it.
