call with 00
Discussion in '3CX Phone System - General' started by lolo168, Mar 3, 2010.
  1. lolo168
    Mar 1, 2010
    is any method to eliminate 00 when call out ?? or prefix 00 in PBX server , I try so many way ..but no luck... please help..thanks
  2. hgcomp
    Aug 7, 2008
    33
    if you try with 9 out?...
  3. sipero123
    Nov 24, 2008
    94
    You can set this as as outbound rule if I follow what you want to do. For example from the UK to dial another UK number with skype gateway I dial 020 xxx xxxx my outbound rule reads this and then changes the number by removing the 0 and adding 0044 to the front of the number to make it compatible with skype dialling requirements.
    Jonathan Hamo
