Callback and dial by name same Queue?
Discussion in '3CX Phone System - General' started by Kevin Burns, May 31, 2017.
  1. Kevin Burns
    Apr 3, 2017
    43
    So I am in a situation where when someone enters a queue they have two options. Either press 2 for callback or press 9 for dial by name. Is this possible? Also we are having a problem where the customer waiting in the queue has to wait for the for the entire prompt before they are allowed to hit 2 for a callback.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,277
    246
    Perhaps an IVR first - then if no response goto the Queue.
  3. Kevin Burns
    Apr 3, 2017
    43
    That could work. However if they are in the IVR and would like to initiate the callback from there, they won't be able to correct? They would have to wait to be transferred to the queue for the callback function to work.
  4. craigreilly
    Feb 1, 2012
    3,277
    246
    If you are in Pro version - you might have to work with VAD.
  5. Kevin Burns
    Apr 3, 2017
    43
    I actually didn't know about that thanks. Based off my two minutes of looking it I assume I can just create your own Receptionist?
