Callback on Queue -- No advisement to Press 2
Discussion in '3CX Phone System - General' started by joshuab, Jan 15, 2018.
  1. joshuab
    Feb 2, 2016
    5
    If I have Callback enabled and set to "Triggered on user Requestest (Press 2)". From my testing the caller is never advised that they can Press 2 to go into callback mode. So they would not even be aware that is an option.
    If I choose "Offered to caller..." it "forces" the caller into call back, but does give them the option to cancel (#). Though from my testing if the caller cancels that request they never get the option again and have not been advised that they can "Press 2".
    Is there an ability from either "Triggered on..." or "Offered to..." to advise the caller at any given interval "Press 2 to use callback"? I would prefer to use "Triggered on..." so the user is told they can Press 2 at anytime to get callback. There just is no prompt/advisement that 2 is an option
  2. i3
    i3
    Jun 6, 2012
    29
    I believe you will have record the prompt you use to say, press 2 to be called back.
  3. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    38
    Hello @joshuab
    As @i3 said, you will need to let your callers know of this options by recording a proper intro prompt.
    In order to do this, just enable the option "Play intro prompt" in the General Tan of the Queue Settings and upload or record the desired prompt.
