Callcentric Configuration Question
Discussion in '3CX Phone System - General' started by DuNuNuBatman, Apr 6, 2007.
  1. DuNuNuBatman
    Feb 26, 2007
    13
    I have set up and registered callcentric as my voip provider along with broadvoice. The problem I am running into now is when I try to call in, I get an all circuits are busy error.
    I was told that was because I had the wrong phone number, but when I tried to change the phone number, it still doesn't work and I get the same error.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,915
    221
    Do you get this error when calling the number via the PSTN? It sounds like a PSTN error, i.e something to do with Callcentric? Let me know if i misunderstood.
  3. DuNuNuBatman
    Feb 26, 2007
    13
    When I call in, this is the log events captured.
    11:10:07.948 ??: from 'phone:0/MediaServer':EP 00000037@10.0.0.12.Failed to open file "C:WINDOWSTEMPprmpt25ec39.wma" to play on EP 00000037@10.0.0.12. 'silent' RTP stream will be sent.
    11:04:00.251 StratInOut::eek:nHangUp Call from Ln:10001@Callcentric to 300 has been terminated
    11:03:59.751 CallLegImpl::eek:nConnected Established media channel for Ln:10001@Callcentric: remote=204.11.192.23:51840; local=24.56.xxx.xxx:60609
    11:03:59.704 CallConf::eek:nIncoming Incoming call from Ln:10001@Callcentric to sip:1303997xxxx@ss.callcentric.com
    When I disable the inbound calling in the admin menu, I get a callcentric error message. But when I enable it, I get the following error message:
    "All circuits are busy, please try your call again later, announcement 8 switch 58 dash 2"
  4. DuNuNuBatman
    Feb 26, 2007
    13
    I just noticed your announcement for testing voip providers. Where do I sent my settings information?
  5. Nick Galea
    Jun 6, 2006
    1,915
    221
    Thanks for your willingness to send the settings.
    Please send it to support at 3cx.com. Well test it asap. Because of easter next week some our staff are on holiday. But well try to test it anyway and if not latest the week after that well have results.
    I noticed something else in your post though, the log refers to a file in an invalid path. (with backshlashes). Did you remove those?
  6. DuNuNuBatman
    Feb 26, 2007
    13
    hhhmmm, that's odd. It removed the \ when I pasted the log
    C:\WINDOWS\TEMP\prmptc08295.wma this is the path that was specified.
  7. Nick Galea
    Jun 6, 2006
    1,915
    221
    I think the forum software removes the / to guard against cross site scripting & sql injection attacks. I will check upon the error and get back to you.
  8. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    We have set up an account on Callcentric and made some tests.
    The problem here is that Callcentrc requires 40 ms audio packets. We're not supporting it yet.
    Best regards,
