CallCentric: Unable to call in or out...
Discussion in '3CX Phone System - General' started by pixais, Jul 23, 2008.
  1. pixais
    Jul 23, 2008
    I set the server up (3CX Phone System Version6.0.664.0) and all looks ok with all green symbols for line status on my 3CX VoIP clients and VoIP status: Registered. On my CallCentric dashboard, its telling me that my "Phone is not registered". The one weird thing is that when I first created the VoIP line and used the defaults I was able to get a Phone Registered on CallCentric, but was still unable to call in or out. Then when I followed the 3CX install instructions on CallCentric and re-registered the line within 3CX, it became un-registered on CallCentric.
    This is the error I get when I try to make a call out on one of the softphones:
    09:19:35.721 Call::Terminate [CM503008]: Call(10): Call is terminated
    09:19:35.705 Call::RouteFailed [CM503015]: Call(10): Attempt to reach [sip:19082274603@192.168.0.199:5060] failed. Reason: Not Found
    09:19:35.705 CallCtrl::eek:nSelectRouteReq [CM503014]: Call(10): No known route to target: [sip:19082274603@192.168.0.199:5060]
    09:19:35.689 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:19082274603@192.168.0.199:5060]
    09:19:35.689 Extension::printEndpointInfo [CM505001]: Ext.01: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX_VoIP_Client] Transport: [sip:192.168.0.199:5060]
    When I try calling in, it just keeping ringing and never connects.
  2. Anonymous
    Anonymous Guest
    To get technical support on this one, you can contact our technical support (This requires commercial edition with support package). If you have a commercial edition, but no support package, you can purchase one here:
    https://erp.3cx.com/orderform/support.aspx
