- Joined
- Dec 12, 2013
- Messages
- 95
- Reaction score
- 0
The CallControl API (v14) does not seem to expose a priority property on the TCX.Configuration.OutboundRoute object.
In the PostgreSQL database, the outboundroute table contains an integer-type field priority that, for each unique outboundrule record specifies the order in which each specific route is attempted.
Is there another means by which the order of attempted outbound routes can be specified using the API? Does the order of the array values in the TCX.Configuration.OutboundRule.OutboundRoutes property affect the calling behaviour in this regard?
Thank you.
Thank you.
