Solved Callees cannot hear Caller when he calls from the 3CX App for iOS
Discussion in 'iOS' started by ABerndt, Feb 1, 2018.
  1. ABerndt
    May 23, 2017
    21
    Hello - I have a user that just had to reinstall the 3CX App for iOS on his iPhone 8 after having to reset his phone. When he makes a call, he can hear the person on the other end but they cannot hear him. He has an iPhone 8 with iOS version 11.2.2. I don't use an iPhone so I really don't have anything to reference. Can anyone provide any assistance? Thank you in advance for your help.
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,479
    67
    What's the 3CX client version - in More/Settings/About?
    First check if the microphone is enabled: device Settings/3CX/microphone should be ON
    Then try echo test,*777, see if it's working OK.
  3. ABerndt
    May 23, 2017
    21
    He has version 15.2.12.316. The microphone wasn't turned on. He turned it on and all is well. Thank you so much for your prompt response!
  4. Vali_3CX
    Dec 12, 2008
    1,479
    67
    You're welcome :)
