caller dials extension after reaching IVR
Discussion in '3CX Phone System - General' started by livsan2000, Mar 1, 2013.
  1. livsan2000
    Mar 1, 2013
    Hello all,
    I have a client who wants to set up an IVR like this:
    "Welcome to our company.
    If you know the extension please dial it, if not, wait for the operator."
    So basically he wants that the caller dials the extension and if not go to secretary (ring group).
    Is this possible with 3CX Phone System?
    Thank you.
  2. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    yes, by default when you hear IVR (digital receptionist in 3cx), you can press local extension number and you will be routed to that extenion... or if you wait you can be redirect to secretary or something else (ring group, queue...)
  3. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    Absolutely - that's basically the default behaviour. You configure the options in the IVR to route the call to reception if a valid extension number isn't entered.
  4. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Yes as mixg stated by default you have the option to dial in an extension in the IVR as well as pick the options ie 1 for sales 2 for support etc..... We actually have our system setup similarly though after 2 rings our IVR picks up.
  5. livsan2000
    Mar 1, 2013
    Thanks everyone. It works.
    I didn't realize that it is the basic function in the IVR.
    Thank you.
