Caller disconnected when Dial by Name returns more than 9 results.
Discussion in 'Ideas' started by qsource, Nov 2, 2016.
  1. qsource
    Jul 22, 2010
    Can we have this produce a different result? Currently if you have more than 9 responses from a dial by name query, it just hangs up on the caller. At least point it back to the IVR or allow the admin to point it to a ring group so that caller doesn't get hung up on.
    I searched the forum and did not see anything that pertains to this. If there already is something about this on the forum, please direct me there so I can up vote it please.
    Thank you.
  2. briankayser
    Jul 19, 2016
    49
    5
    Have you tried changing the Parameter "CALLBYNAME_MINLEN" from 3 to 4? With so many similar names this seems the way to go.
    Unfortunately (at least in v14 where I tested this) the voice-prompt still asks for the first 3, but it will wait until you dial 4 if you change the setting. So you'd have to record your own USER_NAME (UserName.wav) in SYSTEM PROMPTS to ask them to enter the first 4 letters...
  3. qsource
    Jul 22, 2010
    I appreciate the reply, however there are over 1700 extensions on the phone system. There are 27 people named smith. Even with 4, it's still too many returns. There are 7 or 8 last names that have more than 10 people on the return list. I would just like it if the system did not hangup on the caller.
  4. briankayser
    Jul 19, 2016
    49
    5
    Those dang Smith's anyway!!
    I can see the dilemma.
    Is this on v15?
  5. qsource
    Jul 22, 2010
