Caller ID Call Queue
Discussion in '3CX Phone System - General' started by joshuab, Feb 2, 2016.
  1. joshuab
    Feb 2, 2016
    5
    Hi there,
    I have a Yealink T46G phone and using 3CX 14.
    Since the upgrade to 14, all incoming calls now have {QueueName}:{CallerID} on my display.
    How do I get rid of it stating the queue name and just the Caller ID info?
    Thanks,
    Josh
    10,375
    231
    As I recall it is under Settings / General / Global options
  3. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,255
    63
    The is correct for all version up to V14 SP1.
    In V14 SP2, you can find the exact same option under Settings -> Company Phonebook -> "Phonebook Options" button.
  4. joshuab
    Feb 2, 2016
    5
    I found it under Troubleshooting > Parameters
    The parameter you need to change is "AppendCIDQueue" and set the value to '0'. It is set to 1 by default
