caller id dissapears
Discussion in '3CX Phone System - General' started by ictwelpje, Jul 8, 2015.
  1. ictwelpje
    Jul 8, 2015
    We work for a company that uses yealink phones.
    When the call comes in, they see the caller's number as expected.
    The moment that the phone gets picked up this number dissapears, at that point in time the only number visible is their own number (so the number that receives the call) .
    When looking in the logs afterwards they once again see their own number instead of the caller's number.
    On our own phones we don't have this problems, yet all settings seem the same. Anyone know how to solve this?
    thank you
    output example:
    caller: xxxxx88
    receiver: xxx2034
    phone rings: ALL: xxx2034
    xxxxx88
    after picking up: ALL:xxx2034
  2. Charles_3CX
    Charles_3CX New Member
    3CX Support
    Jul 6, 2015
    114
    Hi, Is the company in question using the default templates or have they configured any custom Templates?
  3. ictwelpje
    Jul 8, 2015
    looks like they are using a custom template
  4. Charles_3CX
    3CX Support
    Jul 6, 2015
    114
    Custom templates are not supported. They can try to revert to the default templates and test again. If still having an issue then you can open a support ticket for us to look into this further for you.
  5. ictwelpje
    Jul 8, 2015
    will try that even though some seem to still have the default
    thank you for helping
