Caller ID empty when inboud rule forwards to external number
Discussion in '3CX Phone System - General' started by Michael Torfs, Mar 13, 2018.
  1. Michael Torfs
    Jan 23, 2018
    30
    If have an inbound rule for a specific DID configured to forward to an external number outside office hours.
    The forward works perfect. Only the external number does not receive a caller id.
    When I call from an extension in the PBX to the same external number I do get a caller id on the external number.
    Our extensions have no caller id's configured. Only our trunks (we have 2) each have a caller id.
    The forward to external number uses 1 of the 2 trunks, but the configured caller id of this trunk does not show on the mobile phone of this number.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,313
    249
    who is your provider? likely a configuration issue on the trunk.
  3. leejor
    10,744
    281
    The fact that this is happening, suggests to me, that your provider does not like the caller Id number that is being sent, when you forward a call, so it prevents any number from being called.
    As a quick test, before speaking to your provider.... put a number in against one extensions Caller ID (something other than the main trunk number) . Is this sent correctly when calling out? If so, then you know that your provider allows you to send something, other than your "main" numbers, assigned to you by them.
    If they do allow this, then a trunks setting may need to be "adjusted".
    #3 leejor, Mar 13, 2018
    YiannisH_3CX likes this.
