Caller ID from a bridged PBX
Discussion in '3CX Phone System - General' started by Basheerpt, Feb 13, 2018.
  1. Basheerpt
    Feb 15, 2017
    49
    7
    We bridged the Grandstream UCM with 3cx. When calling from Grandstream network, 3cx shows "SIP:<3cx Pbx IP>:5060" instead of passing the original caller ID from grandstream.
    If i call from 3cx network to grandstream, it shows exactly the caller name. no issues.
    Any thoughts on this?
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    38
    Hello @Basheerpt
    In order to troubleshoot this, you'll need to run a wireshark capture on the PBX and see if the caller ID is coming in correctly from the grandstream
  3. Basheerpt
    Feb 15, 2017
    49
    7
    Sorry for the delay. The capture shows the correct header under SIP (INVITE). in 3cx Server as shown below:
    Frame 1885: 1174 bytes on wire (9392 bits), 1174 bytes captured (9392 bits) on interface 0
    Ethernet II, Src: _d7:97:91 (00:01:e8:d7:97:91), Dst: Vmware_aa:52:c2 (00:50:56:ac:52:c2)
    Internet Protocol Version 4, Src: <Grandstream_IP>, Dst: <3cx_IP>
    User Datagram Protocol, Src Port: 5060, Dst Port: 5060
    Session Initiation Protocol (INVITE)
    Request-Line: INVITE sip:1270@<3CxIP> SIP/2.0
    Message Header
    Via: SIP/2.0/UDP Grandstream_IP:5060;rport;branch=z9hG4bKPj4e700b59-7fdb-4816-b68e-186703b33393
    From: "GRANDSTREAM_SITE" <sip:3007@Grandstream_IP>;tag=d6376773-5efe-4a67-8d3f-3a8a728eca4c
    To: <sip:1270@<3CXIP>>
    Contact: <sip:10009@Grandstream_IP:5060>
    Call-ID: 98a44b9f-4ac1-412b-a35a-69eb5831f3e6
    CSeq: 3823 INVITE
    Allow: OPTIONS, INFO, SUBSCRIBE, NOTIFY, PUBLISH, INVITE, ACK, BYE, CANCEL, UPDATE, PRACK, MESSAGE, REFER, REGISTER
    Supported: 100rel, timer, replaces, norefersub
    Session-Expires: 1800
    Min-SE: 90
    X-Grandstream-Transport: trunk
    Remote-Party-ID: "GRANDSTREAM_SITE" <sip:3007@Grandstream_IP>;privacy=off;screen=no
    Max-Forwards: 70
    User-Agent: Grandstream UCM6202V1.4A 1.0.15.16
    Content-Type: application/sdp
    Content-Length: 358
    Message Body
    Thanks for any helpful input
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    Hello @Basheerpt
    Have you connected the 2 systems using the Bridges feature or have you connected them as a trunk? There is also an article on how to bridge an Asterisk PBX to 3CX. Perhaps you can find some useful info there. It is for an older 3CX version but basic principals apply.
    https://www.3cx.com/docs/bridging-asterisk-pbx/
  5. Basheerpt
    Feb 15, 2017
    49
    7
    We connected them as bridged.
    When should we go for a bridge or Trunk?
    From the above trace, the Grandstream clearly sending the CID to the 3cx, but 3cx cannot parse it for some reason.
  6. YiannisH_3CX
    May 10, 2016
    6,016
    420
    As i do not have a Grandstream UCM i will need a capture from the 3CX PBX and the logs of the PBX in verbose so i can have a complete view of that is coming into the PBX and what the PBX is sending to the phone. You will need to restart services after you set the PBX to verbose logging.
    Using a bridge is recommended in these scenarios so i would not recommend going for a trunk just yet. Please send me a p.m. with the link to these files so i can take a closer look.
  7. Basheerpt
    Feb 15, 2017
    49
    7
    Sent in conversation.
    YiannisH_3CX likes this.
