Caller ID from Skype Callers
Discussion in '3CX Phone System - General' started by markparker, Jul 12, 2009.
  1. markparker
    Sep 13, 2008
    8
    Hello Folks,
    I installed the 1st version of the skype gateway when it first came out.. it worked okay.
    However, I have now installed the v2 (the 3cx based one) and it works better. However, along with the lack of DTMF. I used to see the skype name of the caller on my phones... I now don't it just comes up PRIVATE...
    Is this a bug?
    Any ideas - it worked in v1 but not in v2....
    Mark
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,442
    61
    Hi, Mark
    About DTMF I mentioned already this issue (I opened a separate topic with known issues found in this Beta version of the gateway, please check it here http://www.3cx.com/forums/confirmed-bugs-issues-in-2-0-beta-10518.html)
    The missing callerID you're the first one who found it - and I've checked it and indeed it's a bug (in fact, not only a bug, but my own mistake there :oops: :mrgreen: ) so it will also be fixed in the next release.
    Thanks for your feedback
    Regards
    vali
  3. markparker
    Sep 13, 2008
    8
    Wow! I've never been the first at anything!
    I have just done another post... I am totally misunderstanding the Master Skype account... In my mind...
    If Account 1 is busy it should pass to Account 2...
    Now if I Skype account 1 (or account 2) I get a busy signal...
    Can you help?
