Caller ID issue with v7 on transfer.
Discussion in '3CX Phone System - General' started by Denny, Mar 4, 2009.
  1. Denny
    Dec 22, 2006
    15
    On versions 6, the caller ID shows on phone when received, and when transfered to another extension and retains the caller ID. On version 7, caller ID shows on phone when received, but when transfered to another extension it does not retain the caller ID. It will shows the extension caller ID. How can I fix this issue to work the same way from version 6.
  2. Denny
    Dec 22, 2006
    15
    anyone?
  3. htcomm
    Jul 25, 2008
    17
    Hi Denny
    Out of interest, what phones are you using ?
    We have I think the same issue as you with our Grandstream phones.
    However with our Snom 360 phones the caller id correctly transfered.
  4. fruvos
    Jun 30, 2009
    I get the exact same issue here. Worked on 6.x but not on 7.x.
    Phones are Linksys SPA942s, with same symptoms seen on SPA941s.
    Worked fine until 3CX was upgraded from 6.x to 7.x so not a problem with the Linksys handsets
  5. hamdiyigit
    Nov 7, 2007
    9
    I have a same problem .
    My Gateway is Audicodes MP114 -FXO and Linksys SPA942, SPA962 ..
    My 3CX version is 7.1.7139
  6. hamdiyigit
    Nov 7, 2007
    9
    I have I error message from Audiocodes mp114 fxo , when performing call transfer.
    Error message is ;
    (sip_stack)(5958 ) !! [ERROR] SIPCallConnectedState::ReinviteResponse : Can not send reinvite response because m_ReinviteTransaction is NULL
