Caller ID Name incorrect When transfering call to Cell Phone
Discussion in '3CX Phone System - General' started by srpg, Nov 17, 2010.
  1. srpg
    Nov 16, 2010
    I've upgraded 3CX from version 8 to Version 9 SP4. With version 8, when I was transfering a call to my cell phone with the away status, the Caller id Name give me the phone number of the caller.
    Now with the new version, I see the caller ID Name from the line ( Outbound caller ID of the VOIP Provider port number) as if I'm calling from my 3cx phone system.
    If I make the same call to my cell phone from my extension, I see my name as configured in the Outbound caller ID of the extension.
    How can I change it for call forwarding as now I only see my main number for all callers.
  2. srpg
    Nov 16, 2010
    Re: Caller ID Name incorrect When transfering call to Cell P
    Here is the Log file for a call :
    14:02:00.610 [CM503008]: Call(2): Call is terminated
    14:01:56.375 [CM504001]: Ext.202: new contact is registered. Contact(s): [sip:202@70.83.144.42:5060;line=36801/202]
    14:01:53.672 Currently active calls - 1: [2]
    14:01:52.594 [CM503007]: Call(2): Device joined: sip:5143942055@sip05.unlimitel.ca:5060
    14:01:52.594 [CM503007]: Call(2): Device joined: sip:5148893261@sip05.unlimitel.ca:5060
    14:01:46.219 [CM504001]: Ext.225: new contact is registered. Contact(s): [sip:225@173.178.25.229:5060;line=48300/225]
    14:01:45.985 [CM505003]: Provider:[unlimitel] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [HMNet2.1] PBX contact: [sip:5143942055@67.212.73.93:5060]
    14:01:45.985 [CM503002]: Call(2): Alerting sip:5143942055@sip05.unlimitel.ca:5060
    14:01:45.719 [CM503025]: Call(2): Calling VoIPline:5148893060@(Ln.10000@unlimitel)@[Dev:sip:5143942055@sip05.unlimitel.ca:5060]
    14:01:45.672 [CM503004]: Call(2): Route 2: VoIPline:5148893060@(Ln.10001@Unlimitel - 5148893261)@[Dev:sip:5148893261@sip05.unlimitel.ca:5060]
    14:01:45.672 [CM503004]: Call(2): Route 1: VoIPline:5148893060@(Ln.10000@unlimitel)@[Dev:sip:5143942055@sip05.unlimitel.ca:5060]
    14:01:45.672 [CM503010]: Making route(s) to <sip:215@192.168.63.16:5060>
    14:01:45.672 [CM505003]: Provider:[Unlimitel - 5148893261] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [HMNet2.1] PBX contact: [sip:5148893261@67.212.73.93:5060]
    14:01:45.657 [CM503001]: Call(2): Incoming call from 5145267783@(Ln.10001@Unlimitel - 5148893261) to <sip:215@192.168.63.16:5060>
    14:01:45.641 [CM503012]: Inbound office hours rule (5148893261) for 10001 forwards to DN:215
    14:01:06.969 [CM503008]: Call(1): Call is terminated
    14:00:54.375 [CM503007]: Call(1): Device joined: sip:5143942055@sip05.unlimitel.ca:5060
    14:00:54.360 [CM503007]: Call(1): Device joined: sip:5148893261@sip05.unlimitel.ca:5060
    14:00:49.672 Currently active calls - 1: [1]
    14:00:37.938 [CM505003]: Provider:[unlimitel] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [HMNet2.1] PBX contact: [sip:5143942055@67.212.73.93:5060]
    14:00:37.938 [CM503002]: Call(1): Alerting sip:5143942055@sip05.unlimitel.ca:5060
    14:00:37.578 [CM503025]: Call(1): Calling VoIPline:5148893060@(Ln.10000@unlimitel)@[Dev:sip:5143942055@sip05.unlimitel.ca:5060]
    14:00:37.532 [CM503004]: Call(1): Route 2: VoIPline:5148893060@(Ln.10001@Unlimitel - 5148893261)@[Dev:sip:5148893261@sip05.unlimitel.ca:5060]
    14:00:37.532 [CM503004]: Call(1): Route 1: VoIPline:5148893060@(Ln.10000@unlimitel)@[Dev:sip:5143942055@sip05.unlimitel.ca:5060]
    14:00:37.516 [CM505003]: Provider:[Unlimitel - 5148893261] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [HMNet2.1] PBX contact: [sip:5148893261@67.212.73.93:5060]
  3. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Log into the 3CX Management Screen
    Goto >> VoIP Providers
    Select your VoIP Provider and goto Outbound Parameters
    Look in the Veriable Field - look for any enteries that are "OutboundCallerID" and change this to "OriginatorcallerID"
    this should solve your problem.
  4. srpg
    Nov 16, 2010
    That work! Thank you very much for your help.
  5. davidbenwell
    Apr 27, 2010
    704
    Your Welcome
  6. erike4
    Nov 19, 2010
    13
    Thank you 3 (also)
