- Joined
- Oct 26, 2010
- Messages
- 10
- Reaction score
- 0
We are unable to pass through our customize "Outbound Caller ID" under the "Edit VOIP Provider". We contacted the VOIP Provider Group3.ca, their support confirmed they put whatever ID they receive from our the 3CX. They said if we wanted to customize the caller ID we have to do it on your 3CX before sending the calls to them. Please see below long. I do not see anything that applies the "Outbound Caller ID" doing the connection of the call.
Is there anywhere else we need to change for the Caller ID?
********** = our account info to our provider blured out.
10:27:51.605 [CM503008]: Call(32): Call is terminated
10:27:49.843 Currently active calls - 1: [32]
10:27:45.116 Session 1410 of leg C:32.1 is confirmed
10:27:45.006 [CM503007]: Call(32): Device joined: sip:**********@208.69.56.54:5060
10:27:45.006 [CM503007]: Call(32): Device joined: sip:[email protected]:5060
10:27:45.006 [MS210001] C:32.2:Answer received. RTP connection[unsecure]: 208.69.56.54:17624(17625)
10:27:45.006 Remote SDP is set for legC:32.2
10:27:36.691 [MS210003] C:32.1:Answer provided. Connection(transcoding mode[unsecure]):192.168.200.5:7110(7111)
10:27:36.691 [MS210001] C:32.2:Answer received. RTP connection[unsecure]: 208.69.56.54:17624(17625)
10:27:36.691 Remote SDP is set for legC:32.2
10:27:36.691 [CM505003]: Provider:[Group3] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:**********@Our WAN IP ADDRESS:5060]
10:27:36.691 [CM503002]: Call(32): Alerting sip:**********@208.69.56.54:5060
10:27:34.991 [CM503025]: Call(32): Calling VoIPline:*************16198088696@(Ln.10002@Group3)@[Dev:sip:**********@208.69.56.54:5060]
10:27:34.991 [MS210002] C:32.2:Offer provided. Connection(transcoding mode): Our WAN IP ADDRESSS:9022(9023)
10:27:34.944 [CM503004]: Call(32): Route 1: VoIPline:*************16198088696@(Ln.10002@Group3)@[Dev:sip:**********@208.69.56.54:5060]
10:27:34.944 [CM503010]: Making route(s) to <sip:[email protected];user=phone>
10:27:34.944 [MS210000] C:32.1:Offer received. RTP connection: 192.168.200.102:2234(2235)
10:27:34.944 Remote SDP is set for legC:32.1
10:27:34.944 [CM505001]: Ext.102: Device info: Device Identified: [Man: Polycom;Mod: SoundPoint IP Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [PolycomSoundPointIP-SPIP_550-UA/3.3.1.0769] PBX contact: [sip:[email protected]:5060]
10:27:34.929 [CM503001]: Call(32): Incoming call from Ext.102 to <sip:[email protected];user=phone>
10:27:34.929 [CM500002]: Info on incoming INVITE:
INVITE sip:[email protected]:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 192.168.200.102;branch=z9hG4bK6c75d7583FF50D6D
Max-Forwards: 70
Contact: <sip:[email protected]>
To: <sip:[email protected];user=phone>
From: "Denny Lasaath"<sip:[email protected]>;tag=93EC0DB5-C5EF05DE
Call-ID: [email protected]
CSeq: 2 INVITE
Accept-Language: en
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, INFO, MESSAGE, SUBSCRIBE, NOTIFY, PRACK, UPDATE, REFER
Proxy-Authorization: Digest username="102",realm="3CXPhoneSystem",nonce="414d535c03490f9659:2bdd8ad1172f7be4a24d8574846a2a5d",uri="sip:[email protected]:5060;user=phone",response="4157547db7981a02f40079c4a9d97e3f",algorithm=MD5
Supported: 100rel, replaces
User-Agent: PolycomSoundPointIP-SPIP_550-UA/3.3.1.0769
Allow-Events: talk, hold, conference
Content-Length: 0
Max-Forwards: 70
CSeq: 2 INVITE
Accept-Language: en
Content-Length: 0
