- Joined
- Oct 13, 2007
- Messages
- 6
- Reaction score
- 0
I just purchased a Patton Smartnode 4112 (2-Port FXO gateway) to replace the Grandstream GXW4104 we were using due to unacceptable sound quality & delays during conversation.
The sound quality is much better with the Patton, however, I cannot get the caller ID number to display anylonger on our inbound calls. I have the Patton setup to answer after 2 ring bursts.
Could someone please offer some pointers as to where the problem may be? We can't live without caller ID.
Thanks in Advance!
10:11:40.187 StratLink:nHangUp [CM104001] Call(10): Ext.102 hung up call; cause: BYE; from IP:192.168.1.2
10:01:36.890 CallLegImpl:nConnected [CM103001] Call(10): Created audio channel for Ln:10000@Patton SmartNode 4112 (192.168.1.101:4878) with Media Server (192.168.1.5:7038)
10:01:36.890 StratInOut:nConnected [CM104005] Call(10): Setup completed for call from Ext.102 to Ln:10000@Patton SmartNode 4112
10:01:36.890 CallLegImpl:nConnected [CM103001] Call(10): Created audio channel for Ext.102 (192.168.1.2:5004) with Media Server (192.168.1.5:7036)
10:01:32.812 CallConf:nIncoming [CM103002] Call(10): Incoming call from 102 (Ext.102) to sip:[email protected]:5060
05:58:21.265 StratInOut:nHangUp [CM104007] Call(9): Call from Ln:10000@Patton SmartNode 4112 to 999 has been terminated by Ln:10000@Patton SmartNode 4112; cause: BYE; from IP:192.168.1.101
05:57:30.171 CallConf:nProvisional [CM103003] Call(9): Ext.101 is ringing
05:57:24.718 MediaServerReporting:TMFhandler [MS211000] Call(9) Ln:10000@Patton SmartNode 4112: DTMF (RTP) from 192.168.1.101:4876 arrived. in-band DTMF tone detection is turned off.
05:57:20.046 CallLegImpl:nConnected [CM103001] Call(9): Created audio channel for Ln:10000@Patton SmartNode 4112 (192.168.1.101:4876) with Media Server (192.168.1.5:7032)
05:57:20.015 CallConf:nIncoming [CM103002] Call(9): Incoming call from 10000 (Ln:10000@Patton SmartNode 4112) to sip:[email protected]
05:57:00.843 StratInOut:nHangUp [CM104007] Call(8): Call from Ln:10000@Patton SmartNode 4112 to 999 has been terminated by Ln:10000@Patton SmartNode 4112; cause: BYE; from IP:192.168.1.101
05:56:32.203 CallConf:nProvisional [CM103003] Call(8): Ext.102 is ringing
05:56:26.734 MediaServerReporting:TMFhandler [MS211000] Call(8) Ln:10000@Patton SmartNode 4112: DTMF (RTP) from 192.168.1.101:4874 arrived. in-band DTMF tone detection is turned off.
05:56:23.906 CallLegImpl:nConnected [CM103001] Call(8): Created audio channel for Ln:10000@Patton SmartNode 4112 (192.168.1.101:4874) with Media Server (192.168.1.5:7028)
05:56:23.890 CallConf:nIncoming [CM103002] Call(8): Incoming call from 10000 (Ln:10000@Patton SmartNode 4112) to sip:[email protected]
04:39:27.671 StratInOut:nHangUp [CM104007] Call(7): Call from Ln:10000@Patton SmartNode 4112 to 999 has been terminated by Ln:10000@Patton SmartNode 4112; cause: BYE; from IP:192.168.1.101
04:39:00.296 CallConf:nProvisional [CM103003] Call(7): Ext.102 is ringing
04:38:54.859 MediaServerReporting:TMFhandler [MS211000] Call(7) Ln:10000@Patton SmartNode 4112: DTMF (RTP) from 192.168.1.101:4872 arrived. in-band DTMF tone detection is turned off.
04:38:47.984 CallLegImpl:nConnected [CM103001] Call(7): Created audio channel for Ln:10000@Patton SmartNode 4112 (192.168.1.101:4872) with Media Server (192.168.1.5:7024)
04:38:47.937 CallConf:nIncoming [CM103002] Call(7): Incoming call from 10000 (Ln:10000@Patton SmartNode 4112) to sip:[email protected]
04:33:32.578 StratInOut:nHangUp [CM104007] Call(6): Call from Ln:10000@Patton SmartNode 4112 to 999 has been terminated by Ln:10000@Patton SmartNode 4112; cause: BYE; from IP:192.168.1.101
04:32:41.093 CallConf:nProvisional [CM103003] Call(6): Ext.102 is ringing
04:32:35.531 MediaServerReporting:TMFhandler [MS211000] Call(6) Ln:10000@Patton SmartNode 4112: DTMF (RTP) from 192.168.1.101:4870 arrived. in-band DTMF tone detection is turned off.
04:32:30.781 CallLegImpl:nConnected [CM103001] Call(6): Created audio channel for Ln:10000@Patton SmartNode 4112 (192.168.1.101:4870) with Media Server (192.168.1.5:7020)
04:32:30.734 CallConf:nIncoming [CM103002] Call(6): Incoming call from 10000 (Ln:10000@Patton SmartNode 4112) to sip:[email protected]
23:16:09.671 StratLink:nHangUp [CM104001] Call(5): Ext.102 hung up call; cause: BYE; from IP:192.168.1.2
23:15:49.343 CallLegImpl:nConnected [CM103001] Call(5): Created audio channel for Ln:10000@Patton SmartNode 4112 (192.168.1.101:4868) with Media Server (192.168.1.5:7018)
23:15:49.343 StratInOut:nConnected [CM104005] Call(5): Setup completed for call from Ext.102 to Ln:10000@Patton SmartNode 4112
23:15:49.343 CallLegImpl:nConnected [CM103001] Call(5): Created audio channel for Ext.102 (192.168.1.2:5004) with Media Server (192.168.1.5:7016)
23:15:45.125 CallConf:nIncoming [CM103002] Call(5): Incoming call from 102 (Ext.102) to sip:[email protected]:5060
22:55:35.671 StratInOut:nHangUp [CM104007] Call(4): Call from Ln:10000@Patton SmartNode 4112 to 999 has been terminated by Ln:10000@Patton SmartNode 4112; cause: BYE; from IP:192.168.1.101
22:54:43.703 CallConf:nProvisional [CM103003] Call(4): Ext.101 is ringing
22:54:38.140 MediaServerReporting:TMFhandler [MS211000] Call(4) Ln:10000@Patton SmartNode 4112: DTMF (RTP) from 192.168.1.101:4866 arrived. in-band DTMF tone detection is turned off.
22:54:27.234 CallLegImpl:nConnected [CM103001] Call(4): Created audio channel for Ln:10000@Patton SmartNode 4112 (192.168.1.101:4866) with Media Server (192.168.1.5:7012)
22:54:27.187 CallConf:nIncoming [CM103002] Call(4): Incoming call from 10000 (Ln:10000@Patton SmartNode 4112) to sip:[email protected]
22:52:29.015 StratInOut:nHangUp [CM104007] Call(3): Call from Ln:10000@Patton SmartNode 4112 to 999 has been terminated by Ln:10000@Patton SmartNode 4112; cause: BYE; from IP:192.168.1.101
22:51:51.968 CallConf:nProvisional [CM103003] Call(3): Ext.102 is ringing
22:51:46.515 MediaServerReporting:TMFhandler [MS211000] Call(3) Ln:10000@Patton SmartNode 4112: DTMF (RTP) from 192.168.1.101:4864 arrived. in-band DTMF tone detection is turned off.
22:51:36.125 CallLegImpl:nConnected [CM103001] Call(3): Created audio channel for Ln:10000@Patton SmartNode 4112 (192.168.1.101:4864) with Media Server (192.168.1.5:7008)
22:51:36.078 CallConf:nIncoming [CM103002] Call(3): Incoming call from 10000 (Ln:10000@Patton SmartNode 4112) to sip:[email protected]
22:46:52.906 StratInOut:nHangUp [CM104007] Call(2): Call from Ln:10000@Patton SmartNode 4112 to 102 has been terminated by Ln:10000@Patton SmartNode 4112; cause: BYE; from IP:192.168.1.101
22:46:47.640 CallConf:nProvisional [CM103003] Call(2): Ext.102 is ringing
22:46:42.187 MediaServerReporting:TMFhandler [MS211000] Call(2) Ln:10000@Patton SmartNode 4112: DTMF (RTP) from 192.168.1.101:4864 arrived. in-band DTMF tone detection is turned off.
22:46:31.968 CallLegImpl:nConnected [CM103001] Call(2): Created audio channel for Ln:10000@Patton SmartNode 4112 (192.168.1.101:4864) with Media Server (192.168.1.5:7004)
22:46:31.937 CallConf:nIncoming [CM103002] Call(2): Incoming call from 10000 (Ln:10000@Patton SmartNode 4112) to sip:[email protected]
22:38:05.203 StratInOut:nHangUp [CM104007] Call(1): Call from Ln:10000@Patton SmartNode 4112 to 102 has been terminated by Ln:10000@Patton SmartNode 4112; cause: BYE; from IP:192.168.1.101
22:37:49.062 CallConf:nProvisional [CM103003] Call(1): Ext.102 is ringing
22:37:43.453 MediaServerReporting:TMFhandler [MS211000] Call(1) Ln:10000@Patton SmartNode 4112: DTMF (RTP) from 192.168.1.101:4866 arrived. in-band DTMF tone detection is turned off.
22:37:31.937 CallLegImpl:nConnected [CM103001] Call(1): Created audio channel for Ln:10000@Patton SmartNode 4112 (192.168.1.101:4866) with Media Server (192.168.1.5:7000)
22:37:31.421 CallConf:nIncoming [CM103002] Call(1): Incoming call from 10000 (Ln:10000@Patton SmartNode 4112) to sip:[email protected]
21:56:04.812 ListenConnect [CM114000] SL: connected RJ-PC:0/PHPExtension_0 at [RJ-PC:0]/PHPExtension_0
21:56:03.265 ClientRegs:nSuccess [CM113005] Registration of sip:[email protected] is successful
21:56:02.765 ExtLine::Register [CM110004] Send registration for "Adhesive Solutions LLC"<sip:[email protected]>
21:56:02.765 ExtLine::Register [CM110001] Use External IP for device line registration DN='10005' device='BroadVoice VOIP'
21:56:02.453 StunClient:rocess [CM115002] STUN resolved external IP=72.86.125.231:49152 by server 64.69.76.23
21:56:02.390 StunClient:rocess [CM115001] Send initial STUN request to 64.69.76.23
21:56:02.281 CallMgr::Stack::thread [CM106001] ** Enter Stack Loop **
21:55:57.890 IVRConnected [CM111000] IVR Server is connected
21:55:57.890 ListenConnect [CM114000] SL: connected RJ-PC:5483/IVRServer at [RJ-PC:5483]/IVRServer
21:55:57.015 ListenConnect [CM114000] SL: connected RJ-PC:0/VoiceBoxManagerService at [RJ-PC:0]/VoiceBoxManagerService
21:55:54.187 CallMgr:umThread::thread [CM100004] ** Enter DUM Thread **
21:55:54.000 DBA [CM109000] ** Database connection Ok **
21:55:53.906 CallMgr::Stack::Initialize [CM106000] ** Adding transports **
21:55:53.906 MediaServerConnected [CM112000] Media Server is connected
21:55:53.906 CallMgr::Initialize [CM100003] ** Initializing SIP stack **
21:55:53.906 ListenConnect [CM114000] SL: connected RJ-PC:0/MediaServer at [RJ-PC:0]/MediaServer
21:55:53.906 CallMgr::Initialize [CM100002] Default Local IP address: 192.168.1.5:5060
21:55:53.406 CallMgr::Initialize [CM100001] Version: 3.1.2434.0
21:55:53.406 CallMgr::Initialize [CM100000] Start 3CX PhoneSystem Call Manager
21:55:53.406 LoadLicenceInfo [CM100008] Licence loading error
Thanks in Advance!
