Caller ID on Call Forwarding
Discussion in '3CX Phone System - General' started by LCC, Jul 8, 2011.
  1. LCC
    LCC
    Jul 8, 2011
    42
    This is my first post as I have just set up a version 10 3CX PBX. For the most part everything is working great. CallCentric is my provider. What is happening is when I have a line forwarded to another number the number that appears on the termination point is the caller ID of the forwarding phone, not the originating caller ID. Is there a way to pass the originating caller ID to the termination point?
    Thanks in advance.
  2. willow
    willow Member
    Mar 1, 2011
    471
    make sure that you do not have the caller id set on th voip provider line. I am also not sure in call centric supports caller id that is not on their system i.e. a line that you know. I use voip.ms for most of my installs and this works flawlessly.
  3. LCC
    LCC
    Jul 8, 2011
    42
    Thanks. It has been working correctly from a Caler ID perspective because I have 2 DIDs and they work respectively on their assigned extensions (i.e. the incoming callers ID is shown correctly on the phone). It's only when I have call forwarding on from an extension that it uses the phones DID instead of the originating callers caller ID. So it seems the originating calls Caller ID is lost on forward.
  4. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    most providers, including callcentric probably (I have an accunt with them too) will not allow forwarding caller-ids, not belonging to you for security reasons. This is not the case if the forward is made by the operator, not by the PBX (if you make the forward through the PBX, you use 2 channels, while forwarding via operators uses no channels).
    This is in general. On 3CX to forward caller-ID, you must set in provider's settings | outgoing parameters the user part as Orginator's caller ID (see attached screen-shot)
    Regards
  5. nbailey
    nbailey Member
    Jan 31, 2011
    359
    You can always use the rebound feature with call screening (not available in the free edition) and it will read the caller ID / Caller's prompted name, before accepting the call or send the call back to email.
    Thanks,
    Nate
  6. LCC
    LCC
    Jul 8, 2011
    42
    Thanks, but the 2 DIDs I have are assigned by CallCentric.
  7. willow
    willow Member
    Mar 1, 2011
    471
    Yes, they are both from call centric but the caller id of the caller is not from call centric. this may be the issue. Try eagles pic post above and see if that entry is in your voip provider form.
  8. LCC
    LCC
    Jul 8, 2011
    42
    Thanks. Tried eagle's suggestion, didnt work. Appreciate everyone's assistance
  9. eagle2
    Apr 27, 2011
    1,085
    11
    It's working for me -- with other provider -- there are 3 fields which I changed (be careful with update procedure).
    Regards
  10. LCC
    LCC
    Jul 8, 2011
    42
    Mind sharing the 3 fields?
  11. eagle2
    Apr 27, 2011
    1,085
    11
    I've changed the following 3 fields (seen in the screenshot, posted earlier) to 'OriginatorCallerID':
    Contact: User part
    You need to 'Update' the field before clicking on 'Apply'.
    Note: Changing Display name is not necessary, but may be helpful.
    Have a look at: http://www.3cx.com/blog/voip-howto/forwarding-rules-v9/
    Regards
  12. LCC
    LCC
    Jul 8, 2011
    42
    Thank you! I will try this today and report back.
  13. willow
    willow Member
    Mar 1, 2011
    471
    also for an easy test, you can try just sending out a random caller id on a normal call. if it is blocked when you try to send out a caller id that is not one of your numbers but workes when you do send one of your numbers then the carrier is blocking it.
