Caller ID on internally transferred calls
Discussion in '3CX Phone System - General' started by us1, Sep 11, 2017.
  1. us1
    us1
    Oct 19, 2015
    80
    21
    When the receptionist answers a call, it is transferred to another internal extension. Should the person not answer, the call goes to voicemail and the recipient receives an email. However, the caller ID is that of the person transferring the call and NOT that of the original caller. How do we change this behavior such that, once the person transferring the call hangs up, the caller ID is now that of the original caller?
    I have opened a support ticket with 3cx but I received the usual "replicate and submit wireshark trace". A simple how-to is all I am asking.
    Thanks.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,371
    452
    Hello @us1
    How is the transfer made? Is it a blind transfer or an attended transfer? If the call is forwarded using a blind transfer then you should receive the originator caller ID in the voicemail notification. If you are using an attended transfer then voicemail notification will not include the originator caller ID. This cannot be changed. I am not familiar with your ticket but the engineer probably wants to see the configuration of the PBX and the type of forward used and what else might be causing this behaviour to change.
  3. us1
    us1
    Oct 19, 2015
    80
    21
    As of right now, they are attended transfers. Ideally they want to able to transfer the calls directly to voicemail using a combination of BLF and softkey (they had this on their Cisco system) but that is a different topic.
    Thank you for the response. This is what I was looking for from support.
  4. YiannisH_3CX
    May 10, 2016
    6,371
    452
    Glad i could assist
