Caller ID on Polycom Phones
Discussion in '3CX Phone System - General' started by malimar, Jan 17, 2011.
  1. malimar
    Oct 26, 2010
    10
    All our incoming calls are currently being sent to a Ring Group. The problem is on our Polycom phones it shows the Ring Group on the caller ID. Where do I modify just to show only the incoming caller ID of the caller.
    It it currently showing on our Polycom:
    We are current running the lastest bootrom and firmware for Polycom 550.
  2. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    Open the Management Console and go to...
    Settings -> General -> Global Options
    ... and there use the option 'Append Group and DID names to Caller ID on/off'. Also with the options below this you could choose to 'append' the name so that you see the number first and then the ring group name.
