Caller ID only for certain Operator Extensions
Discussion in '3CX Phone System - General' started by MyndIngegneria, Dec 30, 2016.
  1. MyndIngegneria
    Dec 30, 2016
    Goodmornig,
    do you know how I can set 3cx to show the Caller ID not for all Operator Extensions but only for certain Operator Extensions (privacy reasons)?
    Thank you!!
    Nicola
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Dear MyndIngegneria,
    Do you want on outbound or inbound to set up this rule.
  3. MyndIngegneria
    Dec 30, 2016
    For inbound calls. Now I can see the Caller ID in all Operator Extension.
    Thank you
  4. GiannosC_3CX
    GiannosC_3CX Guest
    Unfortunately this is currently not possible on 3CXPhone System. You can post this as a feature in our 3CX Ideas section.
  5. MyndIngegneria
    Dec 30, 2016
    Ok, thank you GiannosC
