Caller ID = Private
Discussion in '3CX Phone System - General' started by brianp, Feb 23, 2010.
  1. brianp
    Aug 6, 2008
    45
    After upgrading from 3cx phone system v7.x to 8.x, when making external calls the call ID now displays "Private" versus our company name. Any idea what has changed in v8.x to cause this?
    10,360
    226
    I take it you're outgoing calls use a VoIP provider and not a PSTN gateway?
  3. brianp
    Aug 6, 2008
    45
    Yes, that is correct. We are using Broadvox.
  4. StaffKB
    Jan 5, 2010
    97
    Can you try to remove the broadvox connection and recreate it?
    As the templates have changed.
    Please advise
  5. brianp
    Aug 6, 2008
    45
    I'll give that a try later this evening during off hours. i'll post back here later to let you know if that works. Thanks!
  6. brianp
    Aug 6, 2008
    45
    Well, i just upgraded to 3CX Phone System 8.10824, and re-created the Broadvox VOIP connection based on the new script in v8. Unfortunately that didn't help. We still get "private" on the outbound caller id. Any other suggestions?
