Caller ID Problem
Discussion in '3CX Phone System - General' started by jrme1, Jun 14, 2007.
  1. jrme1
    Jun 14, 2007
    26
    Hi, firts of all congratulation for an excellent aplication. Working really great!. :D
    I have some issue with caller id. Why 3cx application not permit each client configuring the caller id desire?. Always use the Caller ID data in the database and not permit be change by the client. I have problem with that, because i have a MV-370 GSM gateway, this gateway is configured like a extension, because is in another location and using and dynamic IP (So i can not configuring like gateway). This device working good, but have the capability of sending the caller ID from the incoming call passtrought to the extension to connect.
    The GSM Gateway is extension 101 and all calls received by GSM line (or PSTN) has been connecting to the extension 100, but i only see the caller id registered in 3cx database for that extension and not the caller id from the number are calling from PSTN to my GSM gateway.
    If i use this device with any SIP provider and connect to another softphone inside the same provider, i can see the caller id from the number was calling me (Because that provider permit change the caller id field for each client). :?
    Thats is the code:
    sip:10000@sip.miplaneta.com SIP/2.0
    Via: SIP/2.0/UDP 190.73.23.37:5060;rport=5060;branch=z9hG4bKcaa75dd6e0a9a3718445061b67404a68
    Max-Forwards: 70
    Contact: <sip:10001@190.73.23.37:5060>
    To: <sip:10000@sip.testing.com>
    From: "01102268800" <sip:10001@sip.testing.com>;tag=1e8084e0
    Call-ID: 4ab4f9052f48dd9458cb37cc05bc5f9f@190.73.23.37
    CSeq: 801 INVITE
    Allow: INVITE, CANCEL, ACK, BYE, NOTIFY, REFER, OPTIONS, INFO, MESSAGE
    Content-Type: application/sdp
    _________________
    Note the caller id is in the from field: "01102268800"
    Any suggestion for doing that, or is not possible???. If not, please take this like a recomendation.
  2. jrme1
    Jun 14, 2007
    26
    Please, somebody know how i can do???
    Thanks :?
  3. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    I afraid, currently it is not possible. We took this possibility into account.
