Caller ID Question
Discussion in '3CX Phone System - General' started by ziptalk, Jan 24, 2009.
  1. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    If I do not set an explicit out-going caller ID then the out-going caller ID (CLI) defaults to the primary number of the ISDN line. This is not what I want. So I explicitly set it to it's DID number.
    However when I do this, should the internal extensions call one another, instead of the Display name of the extension appearing it shows the out-going CLI - what I would like is that only the CLI is sent on external calls, and internal calls it uses the display name.
    Please let me know whether this configuration is possible or whether it's one or the other.
    Thanks,
    Lewis
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    In the DID configuration did you specify a name? If you do , for the internal calls the DID name will appear.
  3. matictec
    matictec New Member
    Mar 31, 2008
    188
    I have the same problem. I think it can not be the correct way to use the CLI on internal Calls as "Display Name".
    Example:
    ext. no. - name - surname - outgoing caller id - Display name on hardphone (snom, grandstream, etc.)
    100 - Support- not set - 4143104450 - not set
    101 - Martin - Mlinski - 4143104450 - not set
    102 - Daniel - Mlinski - not set - Test
    now in 7.1.7139:
    100 > 102 - 102 see in display 4143104450
    101 > 102 - 102 see in display 4143104450
    102 > 100 - 100 see in display Test
    correct way would be
    100 > 102 - 102 see in display Support
    101 > 102 - 102 see in display Martin Mlinski
  4. James21
    Jul 7, 2009
    I have a similar problem, and would like to see my internal calls with a simple name ID. I am getting "not found" on the caller id for most of my internal calls.
  5. ec268
    Apr 18, 2009
    22
    In my experience, it depends on what phone set do you use. In general, some phone set with large display, it shows all caller information (likes Polycom). However, I only get limited infomation when using Grandstream lower model.
