Caller ID shows "Ringer Group" on phones, but works on s/w
Discussion in '3CX Phone System - General' started by ingram, Dec 23, 2013.
  1. ingram
    Oct 24, 2013
    11
    When I call a number that is routed to the 3cx softphone extension, the caller id displays correctly on the softphone (I can see the number of the caller).
    If I route the same number to a ring group, the SNOM phones display "Ring Group" on the caller ID, instead of the callers number.
    Anyone know how to make the phone display the number of the caller, instead of "Ring Group"?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    Re: Caller ID shows "Ringer Group" on phones, but works on s
    Go to settings on the left side of the screen, then general, then find the tab from above for global options and uncheck the setting for "add queue, call group...........to caller ID"
  3. ingram
    Oct 24, 2013
    11
    Thanks, I'll try that and post back the results
