Caller ID spoofing
Discussion in '3CX Phone System - General' started by Razva, May 7, 2017.
  1. Razva
    May 7, 2017
    30
    Hey,
    I'm currently using Asterisk but I want to give 3CX a try. One of the most important requirements, in my case, is caller ID spoofing. The ISP supports it (currently implemented via Asterisk) so there's no limitation at this point.
    Still when setting SIP Trunks -> Edit -> Caller ID -> "Configure Outbound Caller ID" I have no positive result, the system calls from the "real" number.
    As an offtopic, do you know any provider that allows using a "name" as the caller ID, not a number?
    Cheers,
    Razvan
  2. datamerge
    datamerge New Member
    Nov 19, 2014
    176
    22
    In the sip trunk settings under outbound parameters. Set from:user part to "OutboundCallerID". By default it is "authid"
    imecom and Razva like this.
  3. Razva
    May 7, 2017
    30
    Great, worked like a charm! Any hint on how to use a "name" instead of a number?
  4. leejor
    10,754
    285
    There are two fields, number (numeric), and name (alphanumeric). Most (if not all) providers (and the majority of call display devices) are expecting only numeric characters in the number field. I suspect the the best you will be able to do is to send no digits, and a name, or something like all zeros as the number.
  5. Razva
    May 7, 2017
    30
    Understood. But how in the world do some callers (usually telemarketers) show you a "name", not a number? Do they have any special contracts with the local carriers or...?
  6. leejor
    10,754
    285
    I don't recall seeing any like that myself. There is usually a toll free number (valid or not) at the least. Have you tried just leaving the number field empty, or putting in spaces?
  7. Razva
    May 7, 2017
    30
    Offtopic: do you know a provider that offers cheap calls to EU (especially Romania) and offer DID?
  8. Peter Richardson
    Peter Richardson New Member
    Apr 6, 2017
    198
    8
    hey @datamerge, I have just tried doing doing what you suggested by changing the "From: User Part" field to "OutboundCallerID" but it still shows as the "real" number. Are there any other settings I should look at? I have tried also adding the new DID (the one that I want to use as the one that shows on outbound calls) in Sip Trunk -> trunk -> DIDs, and I also set "Main Trunk Number" under "Routing of calls to Main Number" to the new DID also, but this has not helped. Any ideas?
  9. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    @Peter Richardson
    Not all providers accept this and the settings that apply for one provider may not apply for another. The best option is to contact the provider and ask them if they allow this to be done and if they do from which SIP field are they reading the info from. Changing settings in the Outbound parameters without knowing what the provider uses may break outbound calls entirely
  10. Peter Richardson
    Apr 6, 2017
    198
    8
    @YiannisH_3CX
    Thanks very much for that comprehensive answer. I will check with my provider and report back! Thanks again! :)
  11. Peter Richardson
    Apr 6, 2017
    198
    8
    Hey @YiannisH_3CX
    I contacted my provider and they have confirmed that they are able to spoof any DID that we own. I explained that we needed to do that while we port the existing number to the new provider. I have given them the number and asked which field that it will need to be in for it to work. I'll let you know how it goes.
