Caller ID via MyPhone Forwarding to Mobile
Discussion in '3CX Phone System - General' started by claxtro, Aug 1, 2011.
  1. claxtro
    Mar 12, 2011
    22
    Hi All.
    We have a Patton 4960 along with V10 and so far we like what we see in the whole package. What we have found in our continued testing is when an outside call is forwarded to a mobile device via MyPhone, the number always displays the virtual extension number of the trunk, not the originating number. Interestingly enough when the call comes from another internal extension to mobile via MyPhone, the full number is displayed. Has anyone else run into this same issue? Thank you.
    --Rob.
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Try changing outbound parameters for that trunk - 'from' and 'contact' fields, 'user part' to 'originating caller id', instead of 'auth id' (default).
    Regards
  3. claxtro
    Mar 12, 2011
    22
    Hi Orlin,
    Yes indeed that did work...thank you! This forum is truly global and I appreciate you taking the time and helping out an American trying to convince his work that SIP is the one true global standard and it's here to stay...thanks again!
