Caller ID when transferring
Discussion in '3CX Phone System - General' started by turnstoneltd, Oct 29, 2013.
  1. turnstoneltd
    Oct 25, 2013
    Using 3CX PS v11
    When blind transferring (either from the myphone application, or from a Cisco SPA504G phone) the system uses the caller ID set in the voip provider settings. I'd like the call to have the caller ID of either the extension doing the transfer, or the caller ID of the party being transferred.
    What have I missed or is this not possible?
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    the problem is this feature not supported at most providers
    there was a provider called Gizmo was support it
    but it bought from google and closed
