Caller ID
Discussion in '3CX Phone System - General' started by chakos, Jun 12, 2007.
  1. chakos
    Jun 4, 2007
    I have just setup the 3cx application and all working perfect. My configuration is Voip gateway is Linksys 3102 with 2 sip phones linksys 921 & 941. When i call from my mobile to my PSTN line i cannot see on phone display the caller id. i see only Anonymous caller.
    Any Idea?????
  2. Borsoock
    Borsoock New Member
    Apr 8, 2007
    149
    Patience! SPA 3102 CLID forwarding issue has been already adressed and 3CX team is working on fix as far as I know.
    In the meantime you can try workaround suggested by itfarmer:
    On SPA PSTN line set:
    PSTN Answer Delay must be minimum of 3
    PSTN Ring Thru Delay must be a minimum of 1.5
    Marcin
