Solved Caller ID
Discussion in '3CX Phone System - General' started by Tarheels, Nov 7, 2017.
  1. Tarheels
    Dec 22, 2016
    36
    How do I get caller id to pass to my app when my extension is called
    11,086
    325
    If caller ID is being sent, then it should pass it on automatically. What sort of trunking are you using? If it is via a gateway, then a setting may be incorrect. Have you checked the 3CX Activity Log to confirm that caller ID is actually being sent?
  3. Tarheels
    Dec 22, 2016
    36
    The caller id is in the call logs and you can see it on the extension just not the app
  4. leejor
    11,086
    325
    Which App are you using...Android, iPhone...?
    Does caller ID from an internal call show?
  5. Tarheels
    Dec 22, 2016
    36
    iPhone app. Yes internal calls show the name of the extension calling me
  6. leejor
    11,086
    325
  7. Tarheels
    Dec 22, 2016
    36
    Yes that was the same thing. I shut the app down and restarted it and now it receives the caller id. Thanks for the help
